2AZFE cams are now available
Old Jul 24, 2008 | 05:05 PM
paul_dezod's Avatar
Scionetics
KAD
Default 2AZFE cams are now available
Brian Crower Stage 2 NA, Stage 2 Turbo and Stage 3 N/A!
http://www.dezod.com/cat-camshafts3.cfm
Now available at Dezod.
To get the most out of the cams, you will need tuning done. End of story. Cams change the entire volumetric effeciency of the motor. It opens and shuts the valves in a different pattern all together, which means different air flow parameters, which may require more or less fuel, more or less timing in some areas.
Cam profile stock: Dur Dur @ .050 Lift (in)
248/240 212/200 .385"/.355"
Stage 2 N/A Dur Dur @ .050 Lift (in)
264/256 218/214 .385"/.363"
Stage 2 Turbo Dur Dur @ .050 Lift (in)
272/272 222/222 .401"/.401"
Stage 3 N/A Dur Dur @ .050 Lift (in)
280/272 229/222 .415"/.401"
Old Jul 24, 2008 | 05:13 PM
brett561tc's Avatar
sweet
Old Jul 24, 2008 | 05:22 PM
paul_dezod's Avatar
Scionetics
KAD
Yep! I am trying to work on a GB price for those that are interested. Post up if you want in!
Old Jul 24, 2008 | 05:23 PM
TCpete's Avatar
lol... well.. ok ... NA cams are nice and i guess to some extent about time... but theres gotta be a catch... theres gotta be some kind of fuel correction for them... or timing correction.. every manual i've read and tech ive talked to said the same thing about not working with LIFT on our motors...or hell even a dyno on the NA cams them...
paul can you give some info on the cams?? any numbers, tech info, etc etc on how these will affect the NA and TURBO 2az?
Old Jul 24, 2008 | 05:32 PM
paul_dezod's Avatar
Scionetics
KAD
Old Jul 24, 2008 | 05:41 PM
TCpete's Avatar
lol so unless you have a full standalone... fic is almost useless.. darn! for the NA people i mean!! turbo's would not have so many issues..
Old Jul 24, 2008 | 05:48 PM
blacktrdtc's Avatar
HaYu Racing
im still alil curious about these cams. i would like to see the numbers on them before buying.. *watching*
Old Jul 24, 2008 | 05:50 PM
ricexizxgood's Avatar
Any dyno tests done for the NA one yet?
Old Jul 24, 2008 | 06:04 PM
paul_dezod's Avatar
Scionetics
KAD
I have no dyno data from Brian Crower, but the problem with dyno data on cams is that it is heavily dependent upon the cars mods, engine management and tuner. So in other words, the same cam on one car might make 35whp vs another where it makes 10whp.
Old Jul 24, 2008 | 06:05 PM
equinox2355's Avatar
Would the turbo one work well for the S/C or would I have to look elsewhere?
paul_dezod's Avatar
Scionetics
KAD
I'd like to see the S/C fellas run Stage 2 N/A. I think that would be a good balanced cam when not in boost.
Old Jul 24, 2008 | 09:12 PM
mikescion's Avatar
would the stage 2 NA cams work with turbo guys? I know with the stage2 turbo cams you need upgraded springs and retainers and the NA you don't. But i think it would be a nice street able cam. just not sure about the center line if it'll hurt performance for turbo guys.....
Old Jul 24, 2008 | 09:25 PM
Mr_Meaty's Avatar
so with turbo and f/ic, these cams would still require retune? Like what sort of retuning? Just fuel stuff? cause that's all the f/ic really does...
Old Jul 24, 2008 | 09:28 PM
rhythmnsmoke's Avatar
Music City Scions
Yeah, Brian was telling me they make cams now. BAD ****!
I REALLY want to hear what a camed 2az sounds like.
Old Jul 24, 2008 | 09:29 PM
paul_dezod's Avatar
Scionetics
KAD
N/A cams will even work for turbo sure! Anything is better than stock, but I would recommend the VS&R kit on a turbo app for sure to prevent valve float under intense cylinder pressures.
paul_dezod's Avatar
Scionetics
KAD
Fuel and ignition curves will need to be reworked 100%.
Old Jul 24, 2008 | 09:30 PM
paul_dezod's Avatar
Scionetics
KAD
I have heard it. It sounds funny for sure especially when it is a tad "lopy"
Old Jul 24, 2008 | 09:45 PM
Music City Scions
^^NO vid....I'm upset at you Paul...lol.
Old Jul 24, 2008 | 09:50 PM
deathbyc4's Avatar
hmm, little stiff on the pocket and the fact that it needs the spring kit too for 285, i think i'll wait a bit.
also, how would these cams work with your spring kit?
Old Jul 24, 2008 | 09:51 PM
crush02342002's Avatar
^^vid would be nice for sure
