one touch windows its possible????
Old Jul 29, 2008 | 03:17 AM
pierre_tec's Avatar
Default one touch windows its possible????
i just saw this and found it interesting to do it since like all know the xb only have auto on the driver side i will like to do it in all the doors and like the link said also roll up the windows the active the alarm how can i do it ?????
here is the link http://www.electronicsbonanza.com/co...dProduct=11884
Old Jul 29, 2008 | 02:46 PM
john08xb's Avatar
ive been wanting to do this and actually make a switch in the console to roll all 4 windows up and down with one button.
Old Jul 29, 2008 | 04:00 PM
James_Bond's Avatar
Yes it is possible.
You can add DEI 530T's into your car. You will need 2 modules (one for the front and rear windows) and these will allow you to have auto up and down on both sides.
The modules are made for you to be able to roll your windows up and down with your alarm (I have it all setup like this) and are about 50 bucks each.
Google DEI 530T's
Old Jul 29, 2008 | 06:59 PM
pierre_tec's Avatar
but that module work with the factoy alarm? and how i conected?
Old Jul 31, 2008 | 08:31 AM
Dirtyred's Avatar
thats my question. do you have to have an alarm? also, does it turn the factory switches into one touch up/ down?
Old Jul 31, 2008 | 02:43 PM
foose801's Avatar
Utah Scions
Originally Posted by James_Bond
Yes it is possible.
Google DEI 530T's
nice, you beat me to it.... i was gonna post that ;)
yeah the 530t receives an input signal from an alarm and will up all your windows when you lock it.... it also turns your factory switches into one-touch switches...
as been stated, you will need 2 modules
if tieing it into factory keyless/alarm then a relay tied into your door lock wire will do the trick as far as puttin em up.
if you take it to a skilled technician, plan on spending $150-$200 for install. if you're not experienced with these modules they can be a major pain. make sure the module is installed in in your kick-panel, as close to the door as possible, and away from the elements (water will do a number on em and wig-out your windows spontaneously)
good luck mang!
yupinmytC
22
Jul 27, 2024 07:08 PM
alexdrummerr30
Sep 8, 2018 12:18 PM
Pack34
Scion tC 1G ICE & Interior
Sep 27, 2015 07:11 PM
prescottn
Sep 13, 2015 09:04 PM
BlingSlade
Sep 5, 2015 08:52 AM
