Bad Re-Flash?????
Old Aug 7, 2008 | 04:15 AM
JBGsTC's Avatar
Default Bad Re-Flash?????
So I finished my S/C install this evening, and I've got a few problems.
1) When I start the car/car is idling, if I don't give it gas, it won't stay running. (I know the car needs to re-learn the AFR etc, etc.) This occured even after I let the car idle for about 5 minutes to check the belts and everything, then turned it off, then limped it to the gas station and back, and during that trip I discovered the other issues.
2) Speedo doesn't work, but all other gauges in the dash do.
3) "ABS" "Brake" and TPMS lights are on and the TPMS WILL NOT reset.
4) CEL is on, I have not been able to check the code as of yet.
I am thinking that somehow my re-flash didn't fully take to the ecu on the first try, and the dealership didn't bother to keep an eye on it to make sure it took.
Anyone have any ideas?
Thanks in advance!
Old Aug 7, 2008 | 04:26 AM
turbotc06's Avatar
reflash again
only way ....sounds like you killed a few fuses
or stealership screwed up completely
Old Aug 7, 2008 | 04:57 AM
tCtCtC's Avatar
Default Re: Bad Re-Flash?????
to the guy above me
Old Aug 7, 2008 | 06:46 AM
datdude1119's Avatar
to the guy above me...
Old Aug 7, 2008 | 07:05 AM
tCtCtC's Avatar
my bad
Old Aug 7, 2008 | 07:20 AM
SCIONtific_tC's Avatar
i've had my s/c for about 3 months now and when i first got it i had the same problem with the bad idle. i took it back to the dealer and they cleaned out my throttle body and it hasn't died since. although when i first start up and let it idle it falls below 500rpm but never dies. it seems like a bad tune from trd. ive heard other tC's with the same problem.
Old Aug 7, 2008 | 02:45 PM
JBGsTC's Avatar
Well I just talked to TRD Sparks and they said it sounds like a bad reflash to them, I'm also going to call TRD direct and ask Bob his opinion.
This evening I'm going to clean the tb when I get home, and check all my fuses, and I'm going to drop it off to the dealership tomorrow if I can't work everything out before then...
bump for any other help.
Old Aug 8, 2008 | 06:25 PM
JBGsTC's Avatar
So I tried the TB cleaner, it helped some, gonna do it agian this evening.
The dealership has the ECU right now reflashing it again, so I'll post up later if that fixes the problem...
Old Aug 9, 2008 | 09:41 AM
aen's Avatar
aen
throttlebody shouldn't make a real difference our tb are designed to take abuse. let it be dust or dirt.
steeze69
May 24, 2021 02:57 AM
BlingSlade
Oct 19, 2016 12:39 AM
a23r
Feb 1, 2016 04:05 AM
mudguy
Oct 22, 2015 04:31 PM
alexbarspin
Sep 3, 2015 02:04 AM
