Lightweight Flywheel owners please read
Old Aug 7, 2008 | 07:33 PM
B_Real45's Avatar
Default Lightweight Flywheel owners please read
I just had my Competition Clutch Stg4 and 9lb flywheel installed today.
Everything is wonderful except I notice that my idle is a bit low.. and sometimes at a stop it seems like it's just about to stall but it doesn't.
Does everyone else have this issue? Or is it just something as simple as a vacuum leak before the T-body?
The car is otherwise stock.
Old Aug 7, 2008 | 07:45 PM
Scott8's Avatar
did you install it?
The clutch and flywheel shouldn't make the car stall or feel like it may stall.
I have a stage 4 and the 9lb and I never had any issues like you described
Old Aug 7, 2008 | 07:46 PM
B_Real45's Avatar
No, it was done by a reputable transmission shop here locally.
Old Aug 7, 2008 | 08:09 PM
engifineer's Avatar
Did they disconnect your battery duing the install? If so, the idle should be back to normal after driving it a while (20 - 50 miles or so most likely). When you reset the ECU, it will run a bit strange until it relearns its idle points.
Old Aug 7, 2008 | 08:11 PM
B_Real45's Avatar
Hm.. I was wondering this myself.. but my aftermarket radio didn't lose its stations..
I'm gonna go check my trip odo just in case..
Old Aug 7, 2008 | 08:12 PM
engifineer's Avatar
Some headunits will keep their settings as long as they are not powered down past a certain amount of time. The stock one will keep all of its settings except some of the sound settings after the battery is disconnected. I am guessing that is the case.
Old Aug 7, 2008 | 08:14 PM
B_Real45's Avatar
Bingo! Thanks, Engifineer..
My trip A/B says 5.4 miles and I always reset at every gas fill-up. She's at half tank now.. lol.
Old Aug 7, 2008 | 10:12 PM
cmv138's Avatar
keep us updated after you drive it around for a while.
Old Aug 7, 2008 | 10:13 PM
B_Real45's Avatar
ya will do.
Old Aug 7, 2008 | 10:19 PM
Ace83's Avatar
Ronin Scion
yup they most likely removed the battery so the ecu was reset. but what stage do you have? any rattles when launching slow?
Old Aug 7, 2008 | 10:27 PM
B_Real45's Avatar
Yes, the battery was disconnected and the ecu was reset. I just need to wait for it to relearn idle.
It's a Stage 4 clutch - 6-puck sprung hub. I don't really notice any "chatter" or rattles... but the clutch is new and I think that the chatter develops over time but is completely normal.
Right now under slow/light engagement, if the rpm is too low, it just feels like it's going to stall and the car vibrates a little.. nothing major. I'm still getting used to the combination of the strong clamping force and the lightweight flywheel.
Best mod for me so far.
Old Aug 7, 2008 | 10:31 PM
Ace83's Avatar
Ronin Scion
Yeah it tune should go back after some time, i used to have a map that barely holds idle but will give good afrs after its driven about 50miles, crazy scion ecu ahah
Old Aug 9, 2008 | 04:57 PM
B_Real45's Avatar
I just wanted to update you guys on this... the issue is resolved.
The ECU just needed to relearn idle and that's what it did after 20 miles or so. It idles great now. I'm loving this clutch/flywheel combo more and more. Now I just need to justify having it..
Old Aug 9, 2008 | 05:03 PM
cmv138's Avatar
good to hear that everything turned out great for ya. can you do me a favor and let me know if your MPG got better. i have heard that light weight FW can give you better MPG.
Old Aug 9, 2008 | 10:22 PM
B_Real45's Avatar
sure.. I'll have to let you know in a few weeks.. I've been taking a train to work to save money.. lol!
Old Aug 10, 2008 | 12:08 AM
engifineer's Avatar
There is a big debate on this. It reduces rotational inertia, which means it takes less work to increase rpm. However, this means that it is also easier to slow it down as well, so at cruising, you have less rotational inertia to keep it moving. I would say it will be a wash in the end.
Old Aug 10, 2008 | 12:30 AM
B_Real45's Avatar
As long as it doesn't decrease my mpg I'll be happy.
Old Aug 10, 2008 | 01:11 AM
red123's Avatar
im gonna have my tranny cracked open two weeks from now for lsd and trd heavy duty clutch install, the shop asked me if i want to have a light flywheel installed also.
Ive read Dezod's official turbo faq about the flywheel and it seems like its better to leave the stock one alone. Im n/a by the way, might go FI but not anytime soon.
Do you all think its worth it for a daily driven tc? since the tranny is already open and all. How about first gear? Our first gear is really short, does a light wheel flywheel makes it feel shorter bec the engine revs faster now? thanks in advance for your opinions
BrokenTC2
Jan 27, 2015 03:32 AM
NonStopTuning
Jan 20, 2015 05:20 AM
TheTripleC
Jan 4, 2015 06:46 PM
PTUNING
Dec 11, 2014 08:09 PM
2fixA
Sep 29, 2003 08:36 AM
