VRD fog problem
Old Aug 8, 2008 | 02:53 PM
Elijahtc's Avatar
Default VRD fog problem
hey guys i have the VRD fog lights and recently my driver side fog decides some days it wants to work and others it doesn't. when it goes out it just all of a sudden dims out but if i knock on it it comes back on most of the time. anybody know what the problem could be?
Old Aug 8, 2008 | 03:20 PM
O5_TRD_tC's Avatar
HID's or bulbs?
Old Aug 8, 2008 | 03:22 PM
Elijahtc's Avatar
bulbs.
Old Aug 8, 2008 | 03:46 PM
O5_TRD_tC's Avatar
I would check the connect and the bulb itself.
Old Aug 8, 2008 | 03:59 PM
Elijahtc's Avatar
i've got under there and checked the connection and it was fine. idk. may just buy some new bulbs for both of them and hope thats it.
Old Aug 8, 2008 | 08:36 PM
jroc's Avatar
my passenger side fog does the same thing. imma get under my car today and check to see what i can do
Old Aug 8, 2008 | 08:40 PM
InfiniteVisi0n's Avatar
it must be the connection
Old Aug 8, 2008 | 09:21 PM
jroc's Avatar
got under the car found out that when i move the black and white wires where it meets the bulb the light goes on and off. so i made sure the screw under the rubber(in green circle) holding the bulb is tight. then i used a tie strap to hold the wires still(red circle). i drove around my block a few times. so far so good! i will give an update later on to see if it holds.
note-i tied the wires close to the connections so if i hit a bump i wont have the weight of the connections pulling the wires down.
Old Aug 8, 2008 | 09:27 PM
BlckdOutTC's Avatar
mine just didnt work at all the other day, i have the independent mod on it where i tapped it into the ignition fuse, but i just took the fuse out and put it back in and they are dine now
Old Aug 9, 2008 | 06:40 AM
jroc's Avatar
been driving all over the place tonight fog light still working no problem
Old Sep 16, 2008 | 05:40 PM
jroc's Avatar
update on my fogs. the passenger side started going out again.
i took it apart and found that the negative wire(black wire) was not making good contact where it is screwed to the back of the light. also there was a little rust. so i cleaned the screw and the wire and made sure i screwed it in tight and that it was making good contact.
i will be driving around and checking it. ill post up what happens tonight.
YooItsJay
Dec 2, 2015 08:13 AM
bluemex
Oct 14, 2015 03:29 PM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
nastytc
Scion tC 2G Aero & Exterior
Jan 27, 2015 03:50 PM
TheTripleC
Jan 4, 2015 06:46 PM
