Shift Bushing Question...
Old Aug 14, 2008 | 03:50 AM
Schmevin1234's Avatar
Default Shift Bushing Question...
Just installed my TWM performance short shift as well as bushings...
When I installed the shift bushings the instructions said that the bushings were different, and that one goes on the lower vertical spot.. and one on the higher vertical spot. But I couldn't figure out which one they were talking about... is this going to cause a problem? Or does it even matter. I wasn't sure since they are made for a celica..
Old Aug 14, 2008 | 05:58 AM
jackotamo's Avatar
My fidanza short shifter came with bushings and they all looked the same to me, I figured they all came with the same sized bushing.. I didnt install them though. I noticed though that it could be a problem having higher ones installed in the front two bolts because it would be a leverage issue and would pull on the shift links too much.
Old Aug 14, 2008 | 10:03 PM
engifineer's Avatar
Are you talking about the cage risers or the shift cable bushings under the hood?
From what I recall, the ones under the hood are all the same.
Old Aug 15, 2008 | 02:57 AM
Talkin' about the cable bushings under the hood... hopefully you're right, thanks.
BlingSlade
Oct 19, 2016 12:39 AM
Pkdust
Oct 20, 2015 04:27 PM
user9430961
Sep 24, 2015 01:09 PM
TheGovernmenT
Sep 4, 2015 11:57 AM
Wrencher
Jul 29, 2015 03:51 PM
