Brake Screech?
Old Aug 26, 2008 | 02:48 AM
tCaZ's Avatar
Default Brake Screech?
When my friend made a U-turn to the left today, you can hear a brake or screeching noise. Any1 know whats up?
Old Aug 29, 2008 | 03:24 PM
asthmatic's Avatar
man how fast is he driving when u-turning?
Old Aug 29, 2008 | 09:42 PM
tCaZ's Avatar
not fast at all.
Old Aug 30, 2008 | 01:52 AM
nebster's Avatar
you sure its brakes? and not warn tires, brakes don't care what direction you're moving, now my bald ___ tires screeched when i turned even at low speeds but not my brakes
Old Aug 30, 2008 | 07:04 AM
tCaZ's Avatar
tires are 2 months old
Old Aug 30, 2008 | 07:10 AM
hiximrichard's Avatar
actually this is also one of my problems except my brakes screech without and turning.. is this because of my tire wear?
Old Aug 30, 2008 | 08:23 PM
tCaZ's Avatar
the tires are still good and new though
Old Sep 1, 2008 | 07:39 AM
BlkTC's Avatar
either rotors warped and no pads.. uneven wear or something.. you probably need to get under the car and examine the brake pads.. if it's metal on metal.. switch them out asap.
Old Sep 1, 2008 | 09:11 PM
tCaZ's Avatar
ok ty. do u have estimate on cost if that was the problem?
Old Sep 1, 2008 | 09:24 PM
Ace83's Avatar
Ronin Scion
yeah check the rotors if its warped or if the brakes are worn.. you might also check the wheel bearing, a bad one can cause the calipers to rub with rotors and score it really bad but the noise more of a grinding, metal rubbing noise.. if its a screeching noise, i bet its the tires
Old Sep 1, 2008 | 09:27 PM
equinox2355's Avatar
I have the squeal from my brakes, but only some of the time when im braking (probably 75% of the time). Its annoying but I haven't been able to get my car on a lift to take a look.
Old Sep 1, 2008 | 10:31 PM
tCaZ's Avatar
jeez, sounds expensive.
Old Sep 3, 2008 | 03:29 AM
Coolwaterz's Avatar
is it a loud sharp screeching noise?
i noticed a little rubbing when i turn and brake. especially hard turns.
could it be your calipers?
Old Sep 3, 2008 | 04:00 AM
BlkTC's Avatar
maybe you have hawk pads.. hps plus. ceramic pads will eat up your rotors.. i don't know what you have.. but an estimated cost could be quite expensive.. new front rotors and new pads.. maybe 270 give or take..
orrr, you can pm me on a hook up for all four rotors and brake pads for less than that...
Old Sep 3, 2008 | 11:16 PM
tCaZ's Avatar
ok i will have my body shop check it out, im getting my break calipers painted though
Old Sep 4, 2008 | 07:16 AM
sciontc_mich's Avatar
are you holding the steering wheel at full lock, where it doesn't stop anymore when this noise happens?
Old Sep 5, 2008 | 12:34 AM
tCaZ's Avatar
i dont think so, but there is a posibility.
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
axB
Sep 18, 2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
