Brake Screech?
yeah check the rotors if its warped or if the brakes are worn.. you might also check the wheel bearing, a bad one can cause the calipers to rub with rotors and score it really bad but the noise more of a grinding, metal rubbing noise.. if its a screeching noise, i bet its the tires
maybe you have hawk pads.. hps plus. ceramic pads will eat up your rotors.. i don't know what you have.. but an estimated cost could be quite expensive.. new front rotors and new pads.. maybe 270 give or take..
orrr, you can pm me on a hook up for all four rotors and brake pads for less than that...
Klashan
Sep 24, 2015 12:39 PM
