used wrong weight oil
Old Sep 15, 2008 | 02:41 AM
tronix304's Avatar
Default used wrong weight oil
i got a 07 tc and i accidentally grabbed a 5 qt jug of 5w-30 instead of 5w-20. I haven't drove yet on it. Should i change without driving on it or will it hurt one oil change? suggestions? thanks in advance
Old Sep 15, 2008 | 02:49 AM
AcidDrop's Avatar
i did that once because i was lazy to open my hood at autozone and just grabed the same weight oil. i drove with it for about 3k miles and nothing happened nor did the car feel different, just remember to put the right one next time.
Old Sep 15, 2008 | 02:51 AM
equinox2355's Avatar
5W-30 is what the standard oil was, it shouldn't do any harm, I still run 5W-30 of redline and it runs great!
Old Sep 15, 2008 | 02:52 AM
tronix304's Avatar
thanks guys...also i only have a couple thousand miles left on my warranty...will it void it...i was thinkin bout takin it in for a look-over before the warranty expires
Old Sep 15, 2008 | 02:53 AM
Sciond's Avatar
you will be fine
Old Sep 15, 2008 | 02:59 AM
SquallLHeart's Avatar
well bond.. you have the older engine..
'07s are meant to have 5w20.. but one change of 5w30 won't hurt. i'd change it at 3K at that point though.. you can run it for awhile.. but i'd change it out.
Old Sep 15, 2008 | 03:01 AM
tronix304's Avatar
will do...and what about the warranty issue?
Old Sep 15, 2008 | 03:02 AM
ESEMRFOZZ13's Avatar
5-20 is for fuel saving for the most part unless your in snow you wont be feeling a differance, 5-30 is slightly thicker thats all. i run 5-30 because i redline everyday and drive thru mountains and desert sometimes, so the thicker oil works better for extra heat.
Old Sep 15, 2008 | 03:03 AM
.... no issue.
btw... it's 0w20 that's recommended for winter conditions for the '07+ cars for fuel economy.
5w20 is the new standard for toyota.
Old Sep 15, 2008 | 03:10 AM
tronix304's Avatar
ok thanks guys appreciate it!
Old Sep 15, 2008 | 06:57 PM
chicotunner07's Avatar
i run 0w30, have been for the past 10k miles, didnt notice any difference in gas mileage either
first number is basically the start up viscosity, since were using multi-weight motor oil, second number is the viscosity at running temp
you wont feel anything different, now if you were to run 10w50, you might feel something! LOL
Old Sep 16, 2008 | 10:19 AM
toyota_scion_tc's Avatar
1st you will not notice a difference for a long period of time. It does do harm to your engine in long term if you continue to use the incorrect oil weight, the reason the manufacture requires it due to tolerances for newer engines, only 5w20 will flow sufficient to cool the bearings. It will decrease the life of the engine, and in long term cause bearing failure. Long term means 50K-100K not a few hundred or thousand miles, it may even last longer but if you have two identical engines and change oil when recommended use correct oil weight in one and not the other the engine with the correct oil weight will out last the other one.
XirtaXa
24
Jan 14, 2025 03:49 PM
zzbear
Apr 19, 2015 06:18 PM
kleecker
Apr 4, 2015 02:37 PM
NonStopTuning
Jan 20, 2015 05:20 AM
eric_m
79
Mar 17, 2013 12:21 AM
