S/C owners with management
Old Sep 22, 2008 | 01:11 PM
rhythmnsmoke's Avatar
Music City Scions
Default S/C owners with management
Just wondering if you could chime in on what you did concerning the Reflash from TRD on the ecu. My boy is buying my emanage from me and he has the S/C'er. I understand the reflash messes with you trying to tune the car with alternate management. He has the actual reflash tool itself, and some kind of rom that was replaced. Does he need to re-install the rom that was originally on the ecu or what?
Old Sep 22, 2008 | 04:34 PM
Music City Scions
No one has anything other than the TRD flash?
Old Sep 22, 2008 | 04:39 PM
hunterUnknown's Avatar
to my knowledge the trd flash shouldnt interfere with tuning it with a piggyback any more than a stock ecu would...
id say it would almost save tuning time since it would be a "base map" type of thing.
Old Sep 22, 2008 | 08:55 PM
Music City Scions
I remember someone that went from S/C'er to Turbo, and he mentioned in the post everytime they changed the fueling around, the ECU was pulling timing (due to having the TRD Reflash on it). I would have to look for the thread, but that's what I can remember.
Old Sep 22, 2008 | 09:48 PM
brett561tc's Avatar
your friend should be ok. im almost willing to bet that the timing being pulled was due to our cars very sensitive knock sensor. have you tried asking the local dealership if they can flash it back to base settings, or tried to find some junkyard ecu's?
Old Sep 23, 2008 | 01:43 AM
BoostedBeastBox's Avatar
Id like to know this also, i just picked up a unichip and am going to get tuned soon.
Old Sep 23, 2008 | 02:32 AM
jwaggz82's Avatar
I have the eman ult w/ the trd tune - everything is great - got tuned w/ the 7lb then again w/ my 10.5lb - you get better performance .... dont look at peak hp
Old Sep 23, 2008 | 08:18 AM
Crayola_G's Avatar
m6ar2cel6oTC tuned his turbo setup w/ an emanage while he had the trd reflash installed, talks bout it in the thread, and getting it put back to stock is important. the trd reflash pulls alot of timing away from the emange.
Crayola_G's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=237326
Old Sep 23, 2008 | 09:52 AM
Ace83's Avatar
Ronin Scion
did he have the emanage tuned first or he did the reflash after the emanage tune? if he did the reflash after then that would explain why it wouldnt work with his tune.. im thinking it should be fine
Old Sep 23, 2008 | 11:21 AM
m6ar2cel6oTC's Avatar
yuh it was me about the reflash and turbo. it was pulling timing everytime we tryed to adjust the a/f's. and it didnt pull timing always the same. it kept pulling different timing like one time it will pull 29 then 19 so we just tryed to make it as best as we can. but the dealer can reflash it for 95 bucks. just depends if they wanna do it or not depending on what you have in your engine. cause i called and they told me they can do it for me and then when i took it they caled me a couple of hours later saying they couldnt. which i know thats bull____. i think they saw my turbo under the hood and decided not to mess with the car.
Old Sep 23, 2008 | 01:45 PM
paul_dezod's Avatar
Scionetics
KAD
I have tuned an S/C car with the reflash and alternate engine management. No probs.
Old Sep 23, 2008 | 04:07 PM
05-RS1's Avatar
we had no issues when tuning either. i would think it'd be less work to tune the reflashed ecu, than to bring it back to stock and tune it again. the reflash takes care of a lot of the work, and you can just use the emanage to 'fine tune' it.
k1114
43
Mar 1, 2023 03:08 AM
Greg S
Jul 21, 2016 07:28 PM
Kanchi
Jun 29, 2015 02:42 AM
rshissler
Mar 24, 2015 10:46 PM
