How to Fix a Sqeaky Spring??
Old Oct 17, 2008 | 08:42 PM
TeeCizzle's Avatar
Default How to Fix a Sqeaky Spring??
So my Right Rear Spring is Sqeaking in a High Pitch Tone to where its Annoying to listen to....If you push down and let go there's a High Pitch sqeak coming out...
Anyway to fix this?....Then again I dont even know if its the Spring either!
Aight Thanks in advance.
Old Oct 18, 2008 | 05:04 PM
tcpride's Avatar
Scion Kreationz
LOL, My Car has the same problem in the rear. I Put the TEIN STECH springs. Everything was fine till 2 months passed then every lil bump was a sqeaking horrible sound.
Have you used WD-40 on them????
Old Oct 18, 2008 | 05:09 PM
tcpride's Avatar
Scion Kreationz
BUMP
Old Oct 18, 2008 | 05:34 PM
TeeCizzle's Avatar
Alright....I think I fixed this problem!!
**crosses fingers...
Took off the wheel...Got some WD-40 Sprayed every bushing & contact points like the endlinks to the Rear Sway Bar etc...
Put the wheel back on...Wa-Laa...I was bouncing the crap outta the car...NO Sqeaky sound!!!
Old Oct 18, 2008 | 05:38 PM
tcpride's Avatar
Scion Kreationz
cool, im gonna try that cause my sound is really bad. Especially when the springs are cold in the morning they sqeak like a dying rat!!!!
--------THANX
Old Oct 18, 2008 | 05:56 PM
TeeCizzle's Avatar
Originally Posted by Clean_XB
try wrapping the the lower half of coils that come into contact with eachother with vinyl.
it might be a pain in the butt because you might need to remove the spring off the strut.
I wouldn't recommend just taking WD-40 and spraying random parts
Really?..why not use WD-40??....Just Curious
Old Oct 18, 2008 | 10:38 PM
TeeCizzle's Avatar
Awww Crap...the Sqeak is still happeming...Geesh!
Going to take about the back to see if I can do somethung...
we shall see
Old Oct 19, 2008 | 12:49 AM
jurassic1's Avatar
So do you think it is the springs after doing the (always temporary) wd40 fix? How about slapping some heavy duty grease on the contact points?
If it is the springs (what springs are they anyways?), you could try these Tein silencer rubbers link . I think you can use them on any springs, but verify with them first.
Old Oct 20, 2008 | 05:04 AM
toeveryhour's Avatar
^ he's on progress
Old Oct 20, 2008 | 05:09 AM
maximthegreat's Avatar
watching my stechs also squeak
Old Oct 23, 2008 | 12:17 AM
TeeCizzle's Avatar
WOW....this thread got BIG!...lol
SO I dont have this "sqweaky" sound now...
I went in to get all 4 New tires + an Alignment....
NO more Sqweaky sound!.....LoL...
Old Aug 26, 2010 | 10:24 PM
alaskanpeas's Avatar
this is an old thread i know but i dont want to be harrassed by people saying i didnt search. so ive been noticing a creaking noise with my springs (s.techs) while going over bumps slowly. so today i jacked up the car and saw alot of green on the silencers. well i decided to grease up this contact point and the sound went away. so my question is has anybody taken the silencers off so see if its actually the silencers that are making more noise than reducing it? otherwise im just gunna get a tub of heavy duty grease and hit it up once a month or whenever the sound returns. i can live with it, its just annoying at times.
Old Aug 27, 2010 | 02:05 AM
Dizzzle's Avatar
My Raceland coilovers squeak but I cant tell if its tire rub or the strut/spring.
Old Aug 27, 2010 | 02:24 AM
Spicy_McHaggiz's Avatar
A tire rub will not make a squeaking sound. The most common problem of a "squeak" from the suspension is a blow out strut.
Old Aug 27, 2010 | 02:44 AM
Dizzzle's Avatar
the strut isnt blown. It hasn't been lubed or anything, I will try that.
It makes a squeak as going up my drive way or such and my tire has a bit of rub from my fenders. The struts top part (under the hood) isnt pushed up. It never makes a knocking/rattling sound. And I have a buddy with a rear blown strut so I know what the symptoms are
Old Aug 27, 2010 | 12:53 PM
so.......any one take off the silencer on their s.techs to get rid of the squeaky noise that i inquired about?
Old Aug 28, 2010 | 11:06 PM
sciontc_mich's Avatar
why not try some dry type silicone spray (different than the wet type)??
dry is safe for rubber, to penetrate and seal.
Old Sep 1, 2010 | 10:44 PM
i just used some heavy duty grease. i think it was wheel bearing grease i had laying around, i just put it all over the silencers and bam.....sound gone.
Old Sep 1, 2010 | 11:26 PM
^^ cool good to hear.
DJ_FroZone
25
May 30, 2019 07:17 PM
Monkey343
Scion xD Suspension & Handling
Nov 10, 2016 02:07 PM
mischadoll
Mar 9, 2015 05:48 AM
jcraff3
Feb 20, 2015 11:41 PM
fluxingnation
Dec 26, 2014 04:28 PM
