Duplicolor VHT Paint on Headers?
Old Oct 23, 2008 | 07:35 AM
1vicissitude's Avatar
Default Duplicolor VHT Paint on Headers?
Has anyone had any experience with Duplicolor VHT Very High Temp paint? I believe it says its good to 1500 degrees and has ceramic in it. Would I be able to paint a header with this or would it bubble?
I'm thinking of trying that header exhaust combo on eBay for $200. I've got an itch to try it out because its cheap and wouldn't be to much a waste of money if I decide to go turbo down the road.
____
Old Oct 23, 2008 | 03:01 PM
FishyBusinessXB's Avatar
Default Re: Duplicolor vht paint on headers?
Originally Posted by 1vicissitude
Has anyone had any experience with duplicolor vht very high temp paint? I believe it says its good to 1500 degrees ad has ceramic in it. Would I be able to paint a header with this or would it bubble? I'm thining of trying that header exhaust combo on ebay for $200. I've got an itch to try it out because its cheap and wouldn't be to much a waste of money if I decide to go turbo down the road.
Most paints will keep heat in the exhaust instead of releasing it. This will hurt exhaust scavenging and overall performance. If you do a coating, make sure it expels heat well.
Old Oct 23, 2008 | 04:38 PM
whitebreadbox's Avatar
WHAT? that makes no sense at all. you want cold air into the engine (ie, CAI) and hot gasses to leave as hot as possible (cerama coat, hi-temp paint (which won't work as well)) to increase exhaust scavenging. please read the second paragraph and do other research.
http://www.jet-hot.com/import.html
Old Oct 23, 2008 | 04:45 PM
MeatRocket's Avatar
Wont work. I purchased Duplicolor Hi Heat Header paint. I sprayed my DC-Sport Header on my tC that was rusting. I did all the prep work, followed the directions,
let it dry for a long time. as soon as i put the header an started the car. it started smoking and peeling off.
So I sent the header to Jet-Hot
_____
Old Oct 23, 2008 | 05:55 PM
vettereddie's Avatar
Try Eastwood. They have a lot of brush-on header coatings. Umm, it ain't cheap though, $70 / 8 oz.
For the turbo:
Turbo X black
They have a few other ones a bit cheaper, for a matte silver finish, $26.
Matte silver can
Old Oct 23, 2008 | 05:58 PM
DAILYXB-TYPE-R's Avatar
did you use the header primer?
i've used a header primer "2 coats" then 2coat of header paint. the paint will come out but the primer stay here is mines
hope this helps and good luck
Old Oct 23, 2008 | 05:59 PM
Originally Posted by crazyedie19
wont work. i purchased duplicolor hi heat header paint. i sprayed my dc-sport header on my tc thas was rusting. i did all the prep work, followed the directions, let it dry for a long time. as soon as i put the header an started the car. it started smoking and peealing off.
so i sent the header to jet-hot
do you have a pix
Old Oct 23, 2008 | 06:21 PM
FromTheOld's Avatar
The paint wouldn't have peeled off unless you didn't remove the rust from it before you decided to put a coating of paint. Also, paint won't prevent the rust cause exhaust systems (which includes header/exhaust manifolds) rust from the inside out.
Old Oct 23, 2008 | 06:54 PM
NoLimitzBuilt's Avatar
Team No Limitz
I have painted mine as well and have had not a single issue at all. Here is the Strup one painted with header paint. Been on there for about 2 months now. Still looks brand new. I will have a new pic up this weekend with a different header and paint version as well.
Old Oct 23, 2008 | 07:04 PM
NoLimitzInd what type of paint did you use? I thought from pics I had seen before you just had the ceramic strup header. That looks really nice, specially since I thought it was a unmodified strup piece.
Old Oct 23, 2008 | 07:07 PM
MeatRocket's Avatar
oh i did it right. i sand blasted all the minor surface rust off. primered and painted. i do body work and im good with paint. ill try and find pics. maybe it was a bad can of paint i used. I have the kaminari vented carbon hood and the header would get wet.
Old Oct 23, 2008 | 11:03 PM
Team No Limitz
Ok, you ready for this.. LOL.. I used no primer no nothing. I just cleaned it real well with alcohol and then painted it with hi heat paint. When I get home tonight I will see what paint it was exactly. I just did many coats on it. Here is what it looked like when I started it.
I followed the instructions to the T though. It says to start it let it run for a couple minutes, then shut it off, let it cool, then restart it and let it run for like 10 minutes or something like that. Then it has stayed like that ever sence.
Old Oct 24, 2008 | 01:33 AM
heres some pics w/the cover on w/o the bolt. just got the bolt painted to color match and gotta fix that bracket paint it black to blend it in.
Old Oct 24, 2008 | 04:32 AM
Hypnotik_xB's Avatar
Prep work is key. I have used VHT paint on turbo housings and dowpipes and never had any problems.
Old Oct 25, 2008 | 09:51 PM
Team No Limitz
Here is mine now. I told you guys I would post pics of it this weekend. First are the pics of the way it was with the Strup and then new with the Weapon R one.
Old Oct 26, 2008 | 02:04 AM
looking really good. :D
did you just use the black header paint only?
Old Oct 26, 2008 | 07:04 AM
sp2's Avatar
sp2
Defined3
no limitz you beat me
just need a day off to do my header
looks way sexy
really cant wait to do mine now
Old Oct 27, 2008 | 02:04 AM
you're planning on do it black also?
Old Oct 27, 2008 | 05:34 AM
sp2's Avatar
sp2
Defined3
yep maybe 2mrow
Old Oct 28, 2008 | 12:22 AM
sp2's Avatar
sp2
Defined3
painted valve cover and weapon r header
used duplicolor 1200* ceramic paint
