K & N filter wont fit 06?
Old Oct 25, 2008 | 10:23 PM
silverevo05's Avatar
Default K & N filter wont fit 06?
I just bought the k n Filter and it wont fit my 06 xb? the back tabs cant lock into place
Anyone know how to fix this?
Old Oct 25, 2008 | 11:52 PM
sdsnybny's Avatar
Pics would help
but first thought is it right side up, also might be a front and rear position too
compare it closely to the stock one you took out
check K&N website too see if the part# on box is what should fit your car or if 06 # is diff from 04-05 #
Old Oct 26, 2008 | 03:00 AM
swartzautoman's Avatar
i had one for my 06 and it fit just fine
part # should be 33-2211
Old Oct 26, 2008 | 03:36 AM
I must be slow. I thought because it had that that charcoal filter that maybe the k&n was not fitting because it was for 04-05 I'll try again
Old Oct 26, 2008 | 03:42 AM
jct's Avatar
jct
it will fit just have to keep working at it just a lil be more force to get it to work its just the rubber seal on the filter is just a hair to thick and you have to squish it down with the top half of the air intake box...
Old Oct 26, 2008 | 05:29 PM
the carbon filter is in the top of the air box and wont mess with how your air filter fits
Old Oct 27, 2008 | 06:41 PM
cherry-8's Avatar
Right filter?
KNF 33-2211?
Make sure you have the filter the right way in the intake box -- right side up and front to back. There are indentations in the box for the tabs on the gasket to fit into.
I just put one in my 06 (2.5 weeks ago) and it fit just fine.
In my case, the tabs and arrows on the stock Toyota filter let me know just how the K&N should fit.
MD
Old Oct 27, 2008 | 08:42 PM
ya it's all perfect. I just dont know why it doesnt fit easily like the stock paper one does
Anyways I might just get a new one.
I've doen suspension work and soem mild engine work and the hardest thing is this darn air filter
Old Nov 9, 2008 | 12:35 AM
Noisetube's Avatar
That's right,
On my Vitz it's even worst, it's the same part # but the top part of the box is looking back and it's attached to a very stiff rubber elbow that is attached to the uppipe and the turbo... it's a nightmare.
After 45 minutes... and a lot of kicking the tires and and when my back was about to give in (bent over the hood for that long) I just took a knife, heat it up good in the grill and chopped off just a little bit of the back rubber seal (just removed the 90 degree angle on the back of the rubber seal... don't chop off the whole top of it cause it won't be sealing anymore ) rubbed a drop of Air filter oil on the rubber and it went right in...
Old Nov 9, 2008 | 10:34 PM
SOme of them must be defective. I went to kragen replaced it and BAM 6 seconds and the new one just slipped in
hampton1100
May 28, 2015 07:32 AM
carid
Mar 30, 2015 07:08 AM
Kata
Mar 2, 2015 10:46 PM
Godfryness
Jan 2, 2015 11:18 PM
