What enclosure is this?
Old Oct 27, 2008 | 11:27 PM
c4st's Avatar
Default What enclosure is this?
Old Oct 27, 2008 | 11:38 PM
Scott8's Avatar
Looks like an Elemental Designs stealth set up with 3 JL woofers in it.
Custom job for sure!
Old Oct 27, 2008 | 11:43 PM
silverstreaktc's Avatar
i bet they suck at hitting the lows. amazing mids/high bass im sure tho
Old Oct 28, 2008 | 03:42 AM
cavalierkid888's Avatar
That's jetlounge's box. I believe he made it himself.
Old Oct 28, 2008 | 10:56 PM
nodsetse's Avatar
I suppose that depends on each person's definition of "lows". I'm sure they produce good output in the tC down to at least 30Hz, which I consider good enough "lows".
Old Oct 29, 2008 | 01:29 AM
nebster's Avatar
30 hz is not low, low is like <20 hz
those probably hit around 50 and drop off like mad around 40, they probably suck at 35 hz and below
Old Oct 29, 2008 | 06:07 PM
nodsetse's Avatar
^ It really depends on what you're listening to. To be practical, "low" is whatever the lowest frequencies are in the music you're listening to. If a person doesn't listen to music with much content below 30Hz, then their system doesn't require the capability to go below it.
As for those JLs, they're in a sealed box, such that the rolloff is only 12dB/Oct, then when you factor in cabin gain, they might only be around -3dB @ 30Hz.
javio24
Aug 23, 2015 01:07 AM
trikkonceptz
Jun 7, 2015 01:46 AM
AudioFormz
46
Feb 10, 2007 06:10 PM
Tc_patentman
Oct 28, 2004 07:48 PM
AudioFormz
39
May 2, 2004 09:39 PM
