Headlight bulb blowing out...
Old Nov 5, 2008 | 04:30 PM
TheMerovingian's Avatar
Default Headlight bulb blowing out...
So, a couple weeks ago my passenger headlight went out. I went to autozone and bought a replacement silverstar bulb (mind you, I have had these bulbs for only 3/4 of a year). I noticed last night that my passenger headlight is out again. Grrrr. I did a quick look and there isn't any condensation on the inside of the light and I didn't notice any exposed wires when I changed the bulb a couple weeks ago. What could be causing this?
Old Nov 5, 2008 | 04:36 PM
KrazyAznScion's Avatar
should try putting dielectric grease on the contacts... if you look at the pigtails and you see burn marks it means its arcing.. but other than that i dont know.. so if they're scorched replace the pigtails and apply dielectric grease on aftermarket bulbs..
Old Nov 5, 2008 | 06:42 PM
SquallLHeart's Avatar
did you touch the headlight bulb..?
Old Nov 5, 2008 | 08:06 PM
Negative. I had disposable gloves on both times.
Old Nov 5, 2008 | 08:08 PM
even if you have gloves on, touching the bulb is a no no..
Old Nov 5, 2008 | 08:48 PM
I had them on as a precaution. I didn't touch the bulb, just the gray base.
Old Nov 5, 2008 | 09:16 PM
yeldak's Avatar
my car was doing this, just try cleaning the contacts up, you can use vinegar and something to brush it (I used an acid brush). Then apply the dielectric grease. In my case the bulb wasn't burning out, just cutting in and out.
Old Nov 5, 2008 | 10:33 PM
jurassic1's Avatar
Well, my lowbeam Silverstar Ultras also went out last week. I've had them for about a year +/- 1 month or so. First the passenger's side 2-weeks back , then the driver's this past week.
I was surprised too, I thought they'd last longer than that. Good thing I still had my orig. ones. Ima have to wait for a good rebate to buy another set. Oh well.
Old Nov 6, 2008 | 12:34 PM
That's a little comforting to hear. I ended up putting the stocks back on when the first one blew out. I actually don't remember if I put the new one in the driver's side or passenger's side. So, I'm going to go to autozone tonight and get another one and see if this one blows out. If it does, I'll clean the contacts and use the grease.
Thank you all for your suggestions.
mischman
Sep 15, 2015 03:38 PM
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
kfisher8
Aug 14, 2015 03:21 PM
tenshun
Aug 4, 2015 05:22 PM
SoCal_CJ
Scion tC 1G ICE & Interior
Jul 14, 2015 09:14 PM
