CAR WONT COLD START
Old Nov 8, 2008 | 05:45 PM
chintastictc's Avatar
Default CAR WONT COLD START
my car wont start before its warmed up....i have to plug the stock ecu back in and let in warm up then plug in the emanage to get it goin....and i idle normal for about 5 minutes and then it richens out to 11:1...and at cruidsing sometimes it randomly drops in the 10s....why is this happening????also is there anyone in the nassua county long island area with an emanage blue cable?????? that i can borrow for a couple minutes
Old Nov 8, 2008 | 05:50 PM
purplenitroustc's Avatar
what codes do u have?
Old Nov 8, 2008 | 05:51 PM
ahatch133's Avatar
my car idles super high when its cold but its always started and when i mean high its like 2.3/2.4 grand
Old Nov 8, 2008 | 05:52 PM
ima check rite now ill let you no in a sec
Old Nov 8, 2008 | 05:53 PM
SoFloTC's Avatar
^ that happens..
chin ya get some scangauge goin on
Old Nov 8, 2008 | 05:56 PM
check your plugs also
hows drivability? open and closed loop
Old Nov 8, 2008 | 06:03 PM
VulcanTurbo's Avatar
Does your ecu have programmable cold start settings? Usually it wont start because it needs more fuel when cold, you might have an option to up the fuel curve at low temperatures.
Old Nov 8, 2008 | 06:08 PM
yea lack of fuel is what im thinking
since the emanage alters fuel at open loop (cold starts and WOT) the emanage isnt giving it the fuel it needs
Old Nov 8, 2008 | 06:10 PM
P0300,301,302,303,304.....P0172,P0351,352,353,354...I HAVE A WOT BOX ALSO SO...LOL
Old Nov 8, 2008 | 06:12 PM
WOW
300s are misfires on all cylinders
gotta lookup the other ones
did the problem start after you installed the WOT box by any chance?
either way 2 stepping is probably responsible for the misfire codes
Old Nov 8, 2008 | 06:30 PM
no the wot box didnt do it...i have to get an emanage cable to load up a different map i have for 8 pounds
Old Nov 8, 2008 | 06:33 PM
will it start with the emanage if u keep ur foot partially on the gas? should only have to keep it at like 2K for about 2mins for it to warm up
Old Nov 8, 2008 | 06:34 PM
it cruises normal and then randomly the car gets really rich
Old Nov 8, 2008 | 06:36 PM
no it wont...and by warm up i mean the car has to get to operating temp before i can plug back in the emanage
Old Nov 8, 2008 | 06:42 PM
SoFloTC's Avatar
how does one get misfiring in all cylinders? i had those codes aswell.
Old Nov 8, 2008 | 06:44 PM
coryjames's Avatar
its spark plugs trust me buy them change them
Old Nov 8, 2008 | 06:54 PM
operating temp aka closed loop
once the primary o2 heats up
Old Nov 8, 2008 | 06:59 PM
im going to change the spark plugs
Old Nov 8, 2008 | 09:44 PM
did it work
