CAR WONT COLD START
Old Nov 9, 2008 | 04:31 AM
rhythmnsmoke's Avatar
Music City Scions
Originally Posted by coryjames
its spark plugs trust me buy them change them
+1 Bad plugs, or plugs not gapped right will cause mis-fire in all cyl. Make sure it's colder than stock plugs. And check the gapping on them before install.
Old Nov 9, 2008 | 04:45 AM
m6ar2cel6oTC's Avatar
when you hooked up the emanage did you set the jumper settings? cause i had the same problem when i first got my emanage i never changed the ignition juimper setting from 5v to 12v! trust me its that!!!!!! my car wouldnt start when it was cold i would have to start it with the factory ecu and then when warmed up i then could start it with the emanage, so try that first before you buy new plugs.
Old Nov 9, 2008 | 07:24 PM
chintastictc's Avatar
ordered new plugs
Old Nov 9, 2008 | 07:28 PM
lol i need an emanage cable to do it with
Old Nov 9, 2008 | 11:51 PM
no you dont lol. thats the layout of your emanage. make sure does jumpers are the same as the link i sent you!! if not your car wont start when its cold!! thats how i corrected my cold start issues.
http://www.dezod.com/misc_images/tC%20jumpers.jpg
Old Nov 10, 2008 | 12:16 AM
it never did this before...so why is it all of a sudden doing it now
Old Nov 10, 2008 | 12:33 AM
coryjames's Avatar
plugs
Old Nov 10, 2008 | 12:44 AM
plugs
i have another emanage that starts the car right up
Old Nov 10, 2008 | 12:49 AM
coryjames's Avatar
oh hmmmmmmmmmmm use it then lol
Old Nov 10, 2008 | 03:22 AM
just check the jumper settings lol... or since you got another emanage then use it lol
Old Nov 10, 2008 | 12:45 PM
lol i cant use the other one cuz it wont go anywhere with out misfiring and it idles at 10:1...so i cant use it...
Old Nov 10, 2008 | 12:51 PM
SoFloTC's Avatar
ya cuz it doesnt have a correct map on it
Old Nov 10, 2008 | 01:10 PM
ok then well just do the jumper settings. or check to make sure all the jumper settings are correct. all you have to do it open up the emanage and look.
Old Nov 10, 2008 | 05:00 PM
CarbonXe's Avatar
Sounds like plugs AND tune.
Old Nov 10, 2008 | 05:40 PM
paul_dezod's Avatar
Scionetics
KAD
Default Re: CAR WONT COLD START
Originally Posted by chintastictc
my car wont start before its warmed up....i have to plug the stock ecu back in and let in warm up then plug in the emanage to get it goin....and i idle normal for about 5 minutes and then it richens out to 11:1...and at cruidsing sometimes it randomly drops in the 10s....why is this happening????also is there anyone in the nassua county long island area with an emanage blue cable?????? that i can borrow for a couple minutes
Check jumpers.
Sounds like jumper 2 is wrong
Old Nov 10, 2008 | 08:28 PM
thats what i told him DEZOD! lol
Old Nov 10, 2008 | 08:30 PM
java09's Avatar
i have pics up here somwhere for a guy who had similar issues and setting them properly solved it.
Old Nov 10, 2008 | 08:54 PM
problem solved thanks a million guys....this can be locked now
Old Nov 10, 2008 | 08:55 PM
paul_dezod's Avatar
Scionetics
KAD
What was it?
Old Nov 10, 2008 | 08:56 PM
btw it was the jumper settings
