HKS installed, but having a loss of power???
Old Nov 11, 2008 | 07:36 AM
UncleBuck's Avatar
Default HKS installed, but having a loss of power???
I have 2 gen2's. One with a ApexiN1 Universal and one with a HKS Universal setup. Both are cat-back with straight pipe at 2.25" and no scuba or resonators. The ApexiN1 system has more low-end power (pick-up) and gets better gas mileage than the HKS system!! Does anybody have any idea as to why this is??? I am thinking that it's because the HKS muffler has a larger inlet and outlet, but can that really make for that much of a difference?? Please advise.
Old Nov 11, 2008 | 07:50 AM
fujita_TC's Avatar
yes i think, because you are losing back pressure for having a larger inlet/outlet.
Old Nov 11, 2008 | 01:44 PM
FromTheOld's Avatar
It's all in your head. Unless you have any real numbers, it's all placebo effect and guessing. Changing one muffler, especially ones that have the same design (straight-through can), will do almost nothing for performance (especially because the only difference in this case is at the end of the exhaust system, for about 10-12 inches. That's nothing).
Less backpressure does not mean less low-end torque.
Old Nov 12, 2008 | 08:46 AM
srb219's Avatar
Intersting comment Old, but not true in my case. Running tusdo duals with Weapon R ram intake. Tusdo trumpets installed gained 1.75hp & 2.23 ft. lbs at 3000 RPM on dyno. Love the sound with trumpets removed but want the power gains more right now
Old Nov 12, 2008 | 07:13 PM
Hypnotik_xB's Avatar
Gains so little hardly prove your case. Infact are mostly just dyno variance as one dyno run will never be identical to another.
I agree with Old. Having a little difference in the inlet/outlet at such a small area in the end of an exhaust system will not have any effect.
Old Nov 13, 2008 | 01:48 AM
FromTheOld's Avatar
What's your baseline? Stock vs intake/tsudo exhaust, or intake vs intake/tsudo exhaust? Even then, 2 HP is nothing. I dynoed a car three times and it had more variation than what you had.
Old Nov 13, 2008 | 12:14 PM
srb219's Avatar
Baseline was everything idential except trumps. I love the sound without them but was concerned about back pressure/performance. Yes dyno runs do vary mainly because of engine heat etc. Base was with just warmed engine to temp. Next 2 runs with and without trumpets followed. 1st without, 2nd with
Frustratez
Feb 26, 2015 04:03 PM
missing_image
Feb 7, 2015 07:18 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
cwong1001
Dec 3, 2014 03:30 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
