Safe Boost? .50A/R - Trim 57
Old Nov 20, 2008 | 12:04 AM
johnhawkins's Avatar
Default Safe Boost? .50A/R - Trim 57
Max boost obv depends on a variety of things.
What would be the suggested max boost on the 2AZFE with the following:
T3/T4
Compressor: .50A/R Trim 57
Turbine: .64A/R Trim 76
FMIC With 2.5" Intercooler Piping
550cc Injectors W/ good Tune
Old Nov 20, 2008 | 12:32 AM
Crayola_G's Avatar
with a good tune 10 or 9 psi depending on how aggressive you drive...
geta fuel pump & some watermeth and bring it up to 11-12psi maybe swap the injectors to 750s.......depending on your 550cc injector load.
Crayola_G's Avatar
dont forget a clutch you'll slip away.
Old Nov 20, 2008 | 12:43 AM
SoFloTC's Avatar
750's are way to big for a car that isnt pushin more than 400 whp.
safely? 8-10 psi
even with watermeth 12 psi on a daily driver is hard to be reliable depending on how u drive.
Old Nov 20, 2008 | 03:51 AM
TurboToyotas's Avatar
What FMIC? a good core or one of the typical ones you see?
Piping size means nothing....but if you want it too downsize
Good tune???? Whats your version of a good tune?
What management? Who is tuning it?
There are lots of variables but you'd be suprised on what you can accomplish with the right balance of parts.
Regards-
Todd
Old Nov 20, 2008 | 04:34 AM
java09's Avatar
^^ i agree!
Old Nov 20, 2008 | 12:12 PM
http://www.innovativetuning.com
Right down the street!
Apexi NEO
Open Loop 3
Old Nov 20, 2008 | 12:30 PM
Thank you - Cluth will be a must for sure
I will get the TiAL 8.7 PSI spring.
Old Nov 20, 2008 | 12:52 PM
tcengel's Avatar
9-10 psi is fine. Just make sure you pull a bit of timing for safety.
Old Nov 20, 2008 | 04:28 PM
Is there any EMS that will allow you to change timing?
Old Nov 20, 2008 | 04:29 PM
paul_dezod's Avatar
Scionetics
KAD
AEM FIC will allow you to retard timing.
Old Nov 20, 2008 | 04:36 PM
Sweet - Im gonna run 8.7 with the Neo for now and prob boost up to 10 with the F/IC next summer
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
prescottn
Oct 8, 2015 05:31 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
crimson_sinn
Sep 25, 2015 09:41 PM
goldtoaster
Sep 25, 2015 04:58 AM
