misfire on cyl 1 help.
Old Nov 20, 2008 | 03:14 AM
gingles's Avatar
Default misfire on cyl 1 help.
Ive got an 05 tc that I recently turboed. Its a t3/t4 turbo pushin 7 psi on stock internals. I have a misfire on cyl 1, I'm still runnin stock plugs. The misfire happened one day when I was out tuning so I tightened up the gap from .043 to .035. Everything was runnin great till tonight. It misfired again when I was in full boost. My buddy said its probably boost blowin out the spark so I tightened the gap to .032 tonight. Everything is runnin back to normal.....for now. Anyone know a reason I could be misfiring. Its not my coil pack because I swapped it around and it only stays in cyl 1. I'm also runnin 550 injectors. Could I might not be gettin enough fuel to cyl 1? I still have the stock fuel pump. Or is it time to get some colder plugs? Any info would be helpful.
Old Nov 20, 2008 | 03:19 AM
draxcaliber's Avatar
you should have gotten colder spark plugs when you turbo'ed it, even the trd supercharger comes with one step colder spark plugs.
i'm not saying this will fix your problem for sure, but it is something that you should do anyway.
Old Nov 20, 2008 | 03:56 AM
TurboToyotas's Avatar
Colder plugs will help..check that injector too, could have an issue there.
but at the same time....
welcome to some of the issues with forced induction.
The airflow dist. between the 4 cyl is un even. Some cars notice it more than others.
Thus leading to certain check engine lights.
Regards-
Todd
Old Nov 20, 2008 | 04:07 AM
StreetStarsTc's Avatar
i have misfires in 3 out of 4 cylinders lol
guess i need to tighten the gap on my plugs
but what do you expect, your boosting a car that isn't really meant for turbo
Old Nov 20, 2008 | 04:15 AM
SoFloTC's Avatar
ya i had all 4 cylinders misfiring when i brought the codes up lol
Old Nov 20, 2008 | 08:52 PM
Rydrdg's Avatar
recirc Bov that might help.
yhwhdesign
Jun 11, 2021 03:34 PM
KSwag
Jan 24, 2016 07:52 AM
MeDizzy
Oct 8, 2015 03:31 PM
Jones27able
Scion tC 2G ICE & Interior
Aug 12, 2015 11:26 AM
5N1PE5
Aug 3, 2015 11:25 AM
