need adivce on wiring sub
Old Nov 30, 2008 | 10:47 PM
eastham08's Avatar
Default need adivce on wiring sub
I have a kicker comp vr 8" sub and i was wondering if i should wire it in series or parallel? The amp I have is the Rockford Fosgate 201s.
Here are the specs for the sub:
# Subwoofer Size: 8"
# Peak Power Handling: 400 watts
# RMS Power Handling: 200 watts
# Sensitivity : 83.1 dB
# Frequency Response 30 - 500 Hz
# Impedance: 4 ohms DVC
# Dual Voice Coil: Yes
# Surround Material Santoprene Rubber
# Inverted Structural Dome Polymineral Injection Molded Cone: Remains rigid, and lowers distortion
# Rear Cone Brace: Offers unmatched strength and resistance to deformation
# Ribbed Santoprene Surround for Linear Cone Motion
# Silver-Coated Stamped Steel Basket
# Stitched Surround: Ensures the cone and surround won't seperate, even under the highest loads
# High-temp Polyimide Film Voice Coil Former
# Dual Ultra-Length Voice Coils
# Perimiter Venting
# Sleeved High-Power Tinsel Lead Wires
# Spring Loaded Nickel-Plated Terminals
# Sealed Box Volume: 0.4 - 1.8 cu. ft.
# Ported Box Volume: 0.8 - 1.22 cu. ft.
# Top Mount Depth: 4-5/6"
# Cutout Diameter: 7-1/16"
Thanks for any help
Old Nov 30, 2008 | 11:48 PM
Dr_Isotope's Avatar
Depends entirely on what amp you're hooking it up to. If your amp does 2ohm mono, wire the coils in parallel.
Old Dec 1, 2008 | 12:32 AM
eastham08's Avatar
This is the power output from the amp:
2 x 50W RMS (20Hz to 20kHz) @ 4Ohm
2 x 100W RMS (20Hz to 20kHz) @ 2Ohm
1 x 200W RMS (20Hz to 20kHz) @ 4OhmBridged Mono
Old Dec 1, 2008 | 12:36 AM
Dr_Isotope's Avatar
To get 100% output, you'll need a second sub or a different amp. Your wiring options with the DVC are either 2ohm or 8ohm, and your amp only does 4ohm mono, and 50W into 4ohm stereo-- so the most you can feed the sub is about 100W. Underpowered, obviously.
Old Dec 1, 2008 | 12:40 AM
eastham08's Avatar
what amp would you suggest to run to get the most power out of the sub?
Old Dec 1, 2008 | 12:55 AM
Dr_Isotope's Avatar
You want an amp that makes at least 200w RMS into a 2ohm load. An Alpine MRP-M450 (when tuned properly) would be more than enough, and inexpensive, too.
Old Dec 7, 2008 | 02:14 AM
milanshere's Avatar
just a quick question, anyone know which wire is the remote turn off wire on 08 premium headunit?? i tried searching no luck
Old Jul 22, 2009 | 04:24 AM
DJ08tC's Avatar
Sorry for the big bump, but I am also wondering what wire people used for the remote turn on wire for an amp on the 08 premium headunit. I have read several threads and people keep saying different colors wires
thanks
Old Jul 22, 2009 | 10:49 PM
milanshere's Avatar
i went to an audio store and they set t up so that the ground wire from the d/c or cig lighter is used.
Rob54Monty
Feb 3, 2023 08:26 PM
RokGoblin
Scion tC 1G ICE & Interior
Aug 11, 2015 05:24 PM
domincnTC
Aug 4, 2015 01:47 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
