need adivce on wiring sub
I have a kicker comp vr 8" sub and i was wondering if i should wire it in series or parallel? The amp I have is the Rockford Fosgate 201s.
Here are the specs for the sub:
# Subwoofer Size: 8"
# Peak Power Handling: 400 watts
# RMS Power Handling: 200 watts
# Sensitivity : 83.1 dB
# Frequency Response 30 - 500 Hz
# Impedance: 4 ohms DVC
# Dual Voice Coil: Yes
# Surround Material Santoprene Rubber
# Inverted Structural Dome Polymineral Injection Molded Cone: Remains rigid, and lowers distortion
# Rear Cone Brace: Offers unmatched strength and resistance to deformation
# Ribbed Santoprene Surround for Linear Cone Motion
# Silver-Coated Stamped Steel Basket
# Stitched Surround: Ensures the cone and surround won't seperate, even under the highest loads
# High-temp Polyimide Film Voice Coil Former
# Dual Ultra-Length Voice Coils
# Perimiter Venting
# Sleeved High-Power Tinsel Lead Wires
# Spring Loaded Nickel-Plated Terminals
# Sealed Box Volume: 0.4 - 1.8 cu. ft.
# Ported Box Volume: 0.8 - 1.22 cu. ft.
# Top Mount Depth: 4-5/6"
# Cutout Diameter: 7-1/16"
Thanks for any help
# Perimiter Venting
Thanks for any help
To get 100% output, you'll need a second sub or a different amp. Your wiring options with the DVC are either 2ohm or 8ohm, and your amp only does 4ohm mono, and 50W into 4ohm stereo-- so the most you can feed the sub is about 100W. Underpowered, obviously.
Sorry for the big bump, but I am also wondering what wire people used for the remote turn on wire for an amp on the 08 premium headunit. I have read several threads and people keep saying different colors wires
thanks
thanks
domincnTC
Aug 4, 2015 01:47 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
