VRD fog
I still have the install guide from Vertex Racing for the VRD fog lights for when I installed the lights on my tC. I can get you a copy of it by mail or possibly by fax. Let me know if you would like a copy.
Lol this was one of my easiest installs. Once you get a hang of it you can install the fogs in less then 30 minutes. Just follow his directions. Jack the front of the car up..remove the two engine covers...save all the screws and bolts....remove one bolt from the left side, ground the fog wire to the metal then replace the bolt back on. After that click the fogs in place (left and right) then put the engine covers back on. Simple..and the easiest thing about this install is the interior wiring..which is basically 80% dont for you. All you have to do is plug things in and wa la your done.
like seriously.. the only thing that's not "plug and play" about the install.. is the ground wire you have to connect to the chassis... and the sure.. disassembly of the various parts of the car..
everything else either pops or clicks in.
thanks
hey guys i just finished installing the vrd fogs and it was easy just like yall said. just had one question about the placement of the relay on the side of the fuse box. I bought my kit from someone local and it was never opened but he bought it a while back. is there some kind of clip on the relay that lets you attach it to the side of the box for vrds or no? i just kinda put it in that location for now but i feel that it wont be too secure.
I just installed them too, I didn't have a clip with the kit. I just attached it to a bolt under the dash - above the fuse box. It keeps it out of the way.
And these are SO much easier to install than those "JDM" eBay fog lights which I replaced.
OpTicaL
Sep 16, 2015 10:25 AM
umnitza
Sep 1, 2015 08:06 PM
