Transmission.. ****
Old Dec 13, 2008 | 07:59 PM
silvrtc300's Avatar
Default Transmission.. ****
Does anyone know the trans code for the scion tc.. as well as where to get one.. let me know..
Old Dec 14, 2008 | 01:02 AM
its_ikon's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=35024
Originally Posted by cad455
Automatic Transmission:
- The U241E is a 4-speed electronically controlled automatic transaxle. It uses a gated shift lever as well as a low-mass, low friction design. A "lock-up" torque converter improves highway fuel economy.
Manual Transmission:
- The E350 transmission is a compact, lightweight 5-speed manual. There is a double-cone synchro on the REVERSE gear. Triple-cone synchros can be found on FIRST and SECOND gear. This provides faster gear engagement, smoother shifting, and reduces noise.
Now, on to the gear ratios.
5MT:
1st 3.538
2nd 2.045
3rd 1.333
4th 0.972
5th 0.775
Reverse 3.583
Final Drive 4.235
4AT:
1st 3.943
2nd 2.197
3rd 1.413
4th 1.020
Reverse 3.145
Final Drive 2.740
as for locating one, someone else will need to answer that portion. based on where you live you may need to look online or surrounding states.
Old Dec 15, 2008 | 03:20 AM
toyota_scion_tc's Avatar
I have used www.importautosalvage.com and had things shipped to me, depending on where you are you may want to check your local salvage yards and online to find someone closer.
Old Dec 15, 2008 | 03:24 AM
draxcaliber's Avatar
waitaminute! reverse is an unsynchronized square cut gear! if it was synchronized, that would mean you could engage it while rolling backwards without grinding!
Old Dec 15, 2008 | 05:02 AM
I didn't even pay that any attention but he is correct reverse in not sync.
Old Dec 15, 2008 | 05:09 AM
SVicksTC's Avatar
Dave what happened?
Old Dec 16, 2008 | 04:06 PM
g2autosports's Avatar
Does anybody know if I can use an 07 or up 5 speed transmission on an 05 tC? thank you for any replies.
Old Dec 16, 2008 | 04:23 PM
brett561tc's Avatar
Default Re: Transmission.. ****
did you break yours?
shastylz
May 19, 2011 04:41 PM
dodaddy
Jul 20, 2009 12:06 PM
SoFloTC
60
Jul 8, 2009 10:36 AM
Sniffs
Oct 10, 2006 03:08 AM
pho_shizzle
Jul 6, 2004 04:28 AM
