Retained Cruise Control with aftermarket wheel!!! (pics)
Old Dec 16, 2008 | 11:04 PM
Luc1f3r's Avatar
Default Retained Cruise Control with aftermarket wheel!!! (pics)
ok, so i started with D1G1T4L's write up on how to swap an oem wheel for a quick release set up. took about 30 minutes.
after that i began the hunt for a solution for cruise control. my gf lives 2 hours away and i do the drive every weekend so with out CC
opened the wire bundle with all the wires for everything in the column (wipers, turn signals, CC, radio controls, air bag) i taped up the air bag wires and tucked them out of the way.
then i moved the the bundle with the spiral cable input wires to the new spiral cable location.
then i took the harness that goes from the spiral cable to the stock wheel and extended the wires for the CC.
then plugged in the harness and then the CC, test drive, still works.
now i am i working on a new mounting location for the CC lever. i think i got it but im not sure yet. gona play with that over the next few days and see what i come up with.
ill post pics and updates once its all done.
next up is moving the audio controls to the door... why? ... why not?
this could prolly all be done without retaining the spiral cable bundle but if you ever want to put a stock wheel back in, prolly better to not cut the whole factory harness.
notes:
this doesnt fix the air bag light
this doesnt fix the turn signal auto return
and i cant figure out the horn on the personal wheel to see if i can get that to work lol.
ok, i got everything done.
Before:
first i trimmed the mounting holes off of the CC unit to give me a little extra space:
Before:
After:
then a cut a hole in the side of the plastic to stick in the CC unit:
used a 3/4" grommet to "finish" the opening.
used double sided tape to hold it in place (its a snug fit between the plastic and another harness so tape is more then enough): (pics of other harness)
another angle
after doing this, it may have been smarter to put it on the other side, lol. but that would just be odd....:
pics with ebay flip key and oem key... both go in and come out just fine, just have to hold them a little differently to get (my) hand around the lever:
Stock key:
eBay Flip key:
heres a pic of the clearence of the CC behind the HUB... its like it was made for it :p
all done:
scratched up the plastic trying to drill the hole with a hole drill before switching to the dremel...
***interior is getting repainted BSP, to get rid of all the red! thats why its not in in the after pics, has nothing to do with the install***
on a side note, to those with aftermarket Hubs/wheels... what are you doing to cover the gap? or do you rock the gap?
Old Dec 17, 2008 | 03:07 AM
mattieg's Avatar
wow excellent job!
Old Dec 17, 2008 | 04:29 AM
BZinn1's Avatar
Nice.........also look into the CC for the Yaris.....not the HB but the 4 door one.......seems like it is on the other side of the column......same pins......it should be doable as well.
Old Dec 17, 2008 | 07:38 PM
O5_TRD_tC's Avatar
good stuff!
Old Dec 19, 2008 | 02:59 AM
davedavetC's Avatar
pretty sweet DIY man, good job, nice wheel
Old Dec 23, 2008 | 06:05 PM
carbon_ninja's Avatar
KAD
good job luci
Old Dec 24, 2008 | 04:10 AM
topekatc's Avatar
looks nice...sucks about the air bag light tho
Old Dec 24, 2008 | 09:56 PM
highvoltage1's Avatar
Wow thats awesome!! Great job.
Old Dec 26, 2008 | 01:27 AM
troy2003's Avatar
very impressive man....but you people that go aftermarket with your steering wheel that dont have a flat out show car blow my mind....to each their own though homie....looks sick.
Old Dec 27, 2008 | 05:21 AM
Luc1f3r's Avatar
what am i missing to have a flat out show car? lol
2CTC
Sep 12, 2015 11:33 AM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
