HVAC, Blinkers, Reverse Lights, and Windows all dont work.
Old Dec 20, 2008 | 10:24 PM
deez's Avatar
Default HVAC, Blinkers, Reverse Lights, and Windows all dont work.
a fuse? If so, which one?
Old Dec 22, 2008 | 03:31 AM
SquallLHeart's Avatar
you read your owner's manual first?
Old Oct 26, 2010 | 04:00 AM
jimothy12's Avatar
dude i have the same problem! I was changing the leds on the circuit board for the climate control and now the blinkers dont work, the windows, and my car runs differently now (( i need help!
Old Oct 26, 2010 | 04:44 AM
HOLLOWMANGT69's Avatar
When I had my gauges changed I had some what of the same problem. Found it was the fuze in the fuze box in the engine bay. I would take a look there.
Old Oct 26, 2010 | 02:49 PM
jimothy12's Avatar
Can someone explain how i cant down shift to 3 2 or L also?
Old Oct 26, 2010 | 06:21 PM
driver/owner error
Old Oct 27, 2010 | 07:36 PM
Spicy_McHaggiz's Avatar
Maybe you should make another thread where you call out the people trying to help? Seriously though, like I said yesterday the hvac is no way connected to the shifter. Its driver error.
Old Oct 29, 2010 | 05:07 AM
Dwalkertc's Avatar
This issue can happen sometimes if your alt isn't pushing appropriate power or is failing. Gonna have to test how many amps your getting, it can ALSO happen if you have a bad relay. A single fuse will not cause this check your fuseboxes however they are all on different fuses.
Old Oct 29, 2010 | 04:30 PM
wlfpck's Avatar
I am going to attempt to help you.
However in order for me or anyone to help you.... you must READ THE POSTS THAT PEOPLE PUT UP since you clearly did NOT in your thread that got locked.
1) No one knows what you're talking about because you have the literary skills of a 5 year old. You can't shift 3-2-1. Ok.... is this when you're driving and you try to auto stick it from D-3-2-1? Is it you trying to go 1-2-3-D? What is the problem? Or are you simply saying that you left it in D, but when you floor it at 30 mph, the car does not automatically down shift to 3rd?
2) No one can give you a "here is your exact problem, this is the fix". We are behind keyboards.
3) Your best bet is to get it towed. Honestly... if you don't have the electrical/mechanical expertise to do things yourself, get someone else to do it for you and WATCH and LEARN.
Just also a FYI.... auto sticking where you shift into each gear manually on an automatic (read: AUTOMATIC... NOT sequential) exerts extreme wear and tear on the transmission and will fry your clutch packs.
Old Oct 29, 2010 | 04:31 PM
wlfpck's Avatar
I believe NTB can do a free diagnosis if you haven't found the problem already.
Old Nov 2, 2010 | 06:38 AM
Biddle's Avatar
had the exact same prob. its a fuse in the fuse box under dash. cant remem what one but will check and get back to u
missing_image
Feb 7, 2015 07:18 PM
randomsuper
Jan 25, 2015 01:09 AM
Austin292
Scion tC 1G ICE & Interior
Jan 15, 2015 03:52 AM
toyotaisme
Jan 10, 2015 10:24 PM
IrjI619
Dec 21, 2014 05:04 AM
