HVAC, Blinkers, Reverse Lights, and Windows all dont work.
This issue can happen sometimes if your alt isn't pushing appropriate power or is failing. Gonna have to test how many amps your getting, it can ALSO happen if you have a bad relay. A single fuse will not cause this check your fuseboxes however they are all on different fuses.
I am going to attempt to help you.
However in order for me or anyone to help you.... you must READ THE POSTS THAT PEOPLE PUT UP since you clearly did NOT in your thread that got locked.
1) No one knows what you're talking about because you have the literary skills of a 5 year old. You can't shift 3-2-1. Ok.... is this when you're driving and you try to auto stick it from D-3-2-1? Is it you trying to go 1-2-3-D? What is the problem? Or are you simply saying that you left it in D, but when you floor it at 30 mph, the car does not automatically down shift to 3rd?
2) No one can give you a "here is your exact problem, this is the fix". We are behind keyboards.
3) Your best bet is to get it towed. Honestly... if you don't have the electrical/mechanical expertise to do things yourself, get someone else to do it for you and WATCH and LEARN.
Just also a FYI.... auto sticking where you shift into each gear manually on an automatic (read: AUTOMATIC... NOT sequential) exerts extreme wear and tear on the transmission and will fry your clutch packs.
missing_image
Feb 7, 2015 07:18 PM
randomsuper
Jan 25, 2015 01:09 AM
IrjI619
Dec 21, 2014 05:04 AM
