engine head painting?
Old Jan 6, 2009 | 07:44 PM
sc1onk1lla's Avatar
Default engine head painting?
whats a good method for painting your engine head
Old Jan 6, 2009 | 07:49 PM
rosedaleny806's Avatar
the valve cover?? powder coating is good, if not good prep work high temp paints etc
chicotunner07's Avatar
are you talking about the plastic engine cover? or the acctual Valve Cover?
heres fot the valve cover
https://www.scionlife.com/forums/viewtopic.php?t=152099
Old Jan 6, 2009 | 07:50 PM
digndoug's Avatar
Default Re: engine head painting?
are you referring to the Valve cover? or the entire head? or that cheap plastic Valve cover .. cover?
For the Valve Cover or the Head it self you would need to remove it, use degreaser and then use high temp engine paint. Seems like a lot of work for something pointless and dumb.
the cheap plastic? Remove it, clean with degreaser soap and water, then some high temp plastic spray paint
Old Jan 6, 2009 | 08:13 PM
ScionizedRide's Avatar
plastic cover will be ok with the spray paint, but for the actual valve cover you have to remove all the bolts and gasket, sand blasting it and powder coating would be the best method
Old Jan 6, 2009 | 08:48 PM
vettereddie's Avatar
It's not dumb in certain circumstances. I have a motor I'm building and will be dropping in ~ March. it's a used block though and has the nasty white powder crap that's on old aluminum engines. I want to clean it up and paint it before installing it, a basic gloss or flat black will do. Right now I was thinking clean, degrease, walnut shell blast in open air then paint with high-temp rattle can engine paint.
I'm debating if I should paint the valve cover, head and short block seperate while the're disassembles or wait until it's all back together. Disassembled would be easier to work with but then the bolts wouldn't match.
Old Jul 7, 2009 | 09:07 PM
Crippie's Avatar
1UP Crew
hey vettereddie... did you ever get it done? also, what parts did you use for the build?
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 5, 2015 06:09 PM
JPuehl
Scion tC 2G Wheel & Tire
Jan 22, 2015 02:44 PM
evolving_machine
Jan 13, 2015 08:04 PM
happies713
10
Dec 22, 2003 12:27 AM
