engine head painting?
are you talking about the plastic engine cover? or the acctual Valve Cover?
heres fot the valve cover
https://www.scionlife.com/forums/viewtopic.php?t=152099
Originally Posted by sc1onk1lla
whats a good method for painting your engine head
For the Valve Cover or the Head it self you would need to remove it, use degreaser and then use high temp engine paint. Seems like a lot of work for something pointless and dumb.
the cheap plastic? Remove it, clean with degreaser soap and water, then some high temp plastic spray paint
It's not dumb in certain circumstances. I have a motor I'm building and will be dropping in ~ March. it's a used block though and has the nasty white powder crap that's on old aluminum engines. I want to clean it up and paint it before installing it, a basic gloss or flat black will do. Right now I was thinking clean, degrease, walnut shell blast in open air then paint with high-temp rattle can engine paint.
I'm debating if I should paint the valve cover, head and short block seperate while the're disassembles or wait until it's all back together. Disassembled would be easier to work with but then the bolts wouldn't match.
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 5, 2015 06:09 PM
happies713
10
Dec 22, 2003 12:27 AM
