Shift Knob for people with a shorter reach
Old Jan 8, 2009 | 10:18 PM
Batmobox's Avatar
Default Shift **** for people with a shorter reach
Hi Guys...
I don't post much, although I do read threads fairly often. I've searched for this topic with no success.
I was just curious to see if there was any kind of shift **** or DIYs to extend the shifter a few inches further back. My reach is not very long, and I feel like I have to either over stretch to reach the shifter if I want my legs to be comfortable or bring my seat too far forward to have the shifter at a comfortable reach.
Any thoughts or suggestions? Thanks in advance!!!
Old Jan 9, 2009 | 12:06 AM
Skuff_Box's Avatar
What type of tranny do you have? I know plenty of people who extend the manual trans up to almost touch the roof. I don't know about the auto or about moving the shifter back towards the backseat though.....
Old Jan 9, 2009 | 12:07 AM
Griever's Avatar
You could check out Doc Isotope's Lazyboy shifter..
Old Jan 9, 2009 | 01:20 PM
Batmobox's Avatar
Oh, I have a manual transmission.
I didn't really expect to actually move the entire transmission backwards. I was just hoping that there was some kind of shift **** out there that kind of extended the shifter back a few inches. I tried the shift extension that goes between the shifter and the shift ****, but it feels somewhat flimsy. I was imagining that there would be some kind of elbow-like shift **** that I could use to replace the stock one.
@Griever: I will check out the Doc Isotope's Lazyboy shifter.
Are there any other recommendations?
Thanks!
Old Jan 9, 2009 | 02:10 PM
Improbcat's Avatar
My suggestion would be to get one of this guy's shift extensions in 12mmx1.25 thread. I have one and it is rock solid.
If that makes the throw to 5th too far I have two suggestions.
1) Remove the front two bolts holding the shifter assembly to the floor, go buy longer versions and several washers, stack a 1/4-1/2" of washers under the shifter assembly in the front and install the longer bolts. This will tip the entire assembly back and effectively move the shifter backwards.
2) Remove the shift lever itself and take it to an auto body or welding shop and see if they can heat & bend it so it is angled slightly back.
Old Jan 9, 2009 | 02:16 PM
Improbcat's Avatar
Oh,
With extension installed:
With extension & aluminum shift ****:
Old Jan 9, 2009 | 02:30 PM
burstaneurysm's Avatar
You could get one of the JDM articulated ones.
Old Jan 9, 2009 | 03:42 PM
jct's Avatar
jct
where do i get one of those at?!?!?!
Old Jan 10, 2009 | 01:14 AM
Griever's Avatar
Wow, that looks pretty pimp
Old Jan 10, 2009 | 09:18 AM
Gothbox's Avatar
EZ Baked is making some as well, I know he has made one, and I am sure he could make more.
http://www.ez-bakedcustomz.com/theBo....php?f=16&t=31
Old Jan 10, 2009 | 10:41 PM
WhoKilledTheJAMs's Avatar
I made an extra-long-throw shifter a few months ago!
I bought an 18" piece of conduit, some set screws, a tap, and a drill bit. I sanded the whole thing down, and hit it with some rubbing compound to clean it up.
The shift throw is hilariously long, and I love it. My girlfriend gets ____ed when I elbow her in the gut when I put it in reverse, but it sucks to be her.
https://www.scionlife.com/forums/vie....php?p=3802099
Old Jan 11, 2009 | 01:16 AM
jct's Avatar
jct
pic didn't show up and i get an
Error
Not Found
The requested URL /_a0aQwpTANGY/SQN1X8m3vaI/AAAAAAAAE2A/RxHicmo8j4c/s912/100_4056.JPG was not found on this server.
Old Jan 11, 2009 | 03:19 AM
Error
Not Found
Hmm, weird. It works on my end.
Try this:
Old Jan 11, 2009 | 03:43 AM
jct's Avatar
jct
i find it annoying when i have a person in the front passenger seat when i down shift i the person has to move their leg so i can grab my shifter to shift to a lfrom 5th to 4th gear or the other way around
i know theres a product out there thats like a flat piece of billet thats able to move the shift **** closer to the steering wheel
i just can't find it any more and that its been a couple years since i saw it...
NonStopTuning
Jun 29, 2015 07:42 PM
sciontcguy15912
Apr 7, 2015 06:32 PM
disaster06
Feb 3, 2015 08:50 PM
Scionxa180
Scion xA Aero & Exterior
Jan 8, 2015 08:33 PM
pro710
Dec 29, 2014 06:52 PM
