Screetching But I Don't Thinks It's Brakes
Old Jan 9, 2009 | 04:24 AM
SCIONshane's Avatar
Big Sky Scion
Default Screetching But I Don't Thinks It's Brakes
So I've noticed that sometimes in colder weather, I hear a squealing sound when I get on the brakes...
BUT, before you tell me I need new pads...
I can let off the brakes and then get back on with the same amount of pressure and I won't hear a peep. Usually this happens like, once or twice until the car is warmed up. And once again, this only seems to happen during the winter.
Any ideas?
Thanks guys!
Old Jan 9, 2009 | 04:26 AM
Dkfung88's Avatar
probably rust from ur rotors... how many miles have u driven with those pads?
Old Jan 9, 2009 | 04:34 AM
itlstl13's Avatar
i say surface rust too because my xb does it every once it awhile just like you said
Old Jan 9, 2009 | 01:24 PM
sciontc_mich's Avatar
Default Re: Screetching But I Don't Thinks It's Brakes
Any ideas?
Thanks guys!
it could be rust on the rotors like others have said. easy to check for that, just look behind the wheels, you'll see the rotors. look for rust on the surface.
but what I'm thinking it could be since it only happens in the winter..
you need more grease on the back of the pads and shims, it makes noise while cold cuz it's stuck and then warms up, it moves around. i think that's the problem, easy to fix, have some brake lube slapped on the back of the pads and shims. no more noise.
Old Jan 9, 2009 | 01:41 PM
09tC_CB7's Avatar
^ That was going to be my suggestion. My old car had the same problem. My uncle that did work on the car before me when I did my brake job told me to really grease the back and the shims or I would get squealing.
Another thing, if you do take your brakes apart to do this, get a big can of break cleaner and get rid of all the old dust. Just brake dust build up can cause things to squeal.
Good luck man.
Old Jan 9, 2009 | 08:45 PM
SCIONshane's Avatar
Big Sky Scion
Thanks guys!
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
kleecker
Jan 2, 2015 08:09 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
12
Dec 31, 2014 04:07 PM
kleecker
Dec 31, 2014 09:42 AM
Kiwibox
Dec 15, 2014 09:46 PM
