Power Windows motor defected in the cold weather??
Old Jan 12, 2009 | 01:22 AM
pi_kapp_drift's Avatar
Default Power Windows motor defected in the cold weather??
so yea, i started my car in the afternoon, and it was really cold today (20 degrees w/ windchills of -2). after i warmed up my car, i tried to roll down the windows, but it didnt work. at first, i thought the cold weather would freeze my power windows motor for a little bit. but after while, i tried to roll it down,and it didnt work at all. so, do you think i need a new power windows motor??
Old Jan 12, 2009 | 01:37 AM
XIEmperorIX's Avatar
Did you disconnect the battery recently?
Old Jan 12, 2009 | 01:39 AM
nah, didnt touch the battery.
Old Jan 12, 2009 | 01:41 AM
only the passenger side window can roll down.
Old Jan 12, 2009 | 01:47 AM
well I would try the window reset that is done when you disconnect the battery (its in your owners manual or you can search it out on the forum), maybe something happened and caused the ECU to reset.
I don't think any or enough moisture can get to where the power window motor actually is at to freeze.
Old Jan 12, 2009 | 01:55 AM
true. but, this morning it rained, and most of my windows were icy. i had to wait good 20 mins for everything to melt.
Old Jan 12, 2009 | 02:03 AM
well if the reset doesn't work then take off the door panels and see if any water is in there or if anything is frozen. Hopefully if water got in there it didn't mess up the motor. Check the fuse for it as well before and/or after taking off the panel. Wanna make sure you cover all the possibilities before ripping out the motor and spending the $$ on getting a new one.
Old Jan 12, 2009 | 02:04 AM
scionboi06's Avatar
Team Scionce
you kinda hinted to a resolution, try warming the door panel and see if it works if not reset it and try again. our windows are smarter than us lol when u tried to take it down it may have tripped kinda like our wipers due when they hit something if you dont know what im talking about its in the owners manual good luck!!! post up the results
Old Jan 12, 2009 | 02:10 AM
if its the motor not working, im going to wait until spring comes around to get it fix. right now, its too cold to used the windows, except for drive-thrus. LOL.
Old Jan 12, 2009 | 04:27 PM
ahatch133's Avatar
so if u washed ur car recently or whatnot ive found in the colder weather when it gets low it shakes and moves but i let it dry idk how lol its 13 degrees here BUT it did alarm me...once i put it in my temperate control garage it worked and it was fine so that might be a prob
Old Jan 12, 2009 | 08:17 PM
its working now, i guess it actually did froze the motor.
Old Jan 12, 2009 | 08:24 PM
RCZDesigns's Avatar
When I used to live in MA my windows would freeze too, and if I really needed to get it down I just held the button while pusing downward on the window with the other hand, using my palm, if you know what i'm trying to say.
This was with a ford, so our cars should take it much better
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
CPL_Radar
Mar 5, 2015 05:42 AM
Joeynenj
Nov 25, 2014 05:29 AM
