HID HELP.
Old Jan 14, 2009 | 11:23 AM
1SL0WTC's Avatar
Default HID HELP.
sooo i got my replacement hid kit from 3bspec. and i was wondering should i use the relay harness to plug it or use the PLUG N PLAY? they sent me both with my replacement this time.. they told me to use the plug n play because my previous one had relay harness fuse damage due to water because i had the relay on infront of the car like where mostly everyone puts it...
where do u guys suggest i do? anyone use the plug n play kit from 3bspec? or where do u place the relay harness so it doesnt get touched by water?
Old Jan 14, 2009 | 11:31 AM
Eltaco's Avatar
Unless it is a slim digital ballast that has a "soft start", use the relay harness. The standard "metal can" ballasts can use more watts on start up than a halogen bulb and the tiny 22 gauge stock wiring will eventually melt. Make sure to mount the relay in a "high and dry" spot in the engine compartment.
Old Jan 14, 2009 | 11:43 AM
1SL0WTC's Avatar
mmm ok. do u have hids? where did u install urs? i had my previous ones on behind the upper grill. on the metal frame.
Old Jan 14, 2009 | 11:45 AM
o8tC's Avatar
Default Re: HID HELP.
that kept happening to me. i had no idea what it was. my HIDs just wouldnt turn on. then i changed one of the fuses and they worked. then it happened again. i changed the fuse. and wrapped the fuses and relay with that black electrical tape and put it right in the middle of the battery and intake. havent had problems for a couple months now. you cant really see it unless i tell you its there lol
Old Jan 14, 2009 | 11:49 AM
1SL0WTC's Avatar
ok. so you put it between the intake and the battery? where did u put the ballast? i had my ballast down by the side vents... how stupid of me...
Old Jan 14, 2009 | 11:50 AM
jsingh's Avatar
OhioScions
put the relay near battery and fuse box.
Old Jan 14, 2009 | 11:57 AM
o8tC's Avatar
the driver side ballast is on the right side of the battery..not exactly on the battery but on the bar where what connects to the battery tie down. and the left side is behind the headlight. i cant really explain. i'll pm you a pic.
Old Jan 14, 2009 | 03:24 PM
datdude1119's Avatar
i dont think its the ballast that really mess it. its that stupid relay and fuse.. just keep that dry and you should be fine.. but i would use it no matter what lol
Old Jan 14, 2009 | 09:12 PM
Sciontistical_One's Avatar
Put the relay next to the battery in the engine compartment and you should be all good. Don't put the relay in front of the radiator and it won't catch any water... especially out there in Vegas...
Old Jan 14, 2009 | 09:55 PM
Eltaco's Avatar
Driver side (orange plug is the relay)
Passenger side
Old Jan 14, 2009 | 10:11 PM
1SL0WTC's Avatar
mmmm i seee okay guys! thank you
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
MeDizzy
Oct 8, 2015 03:31 PM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
