Do I need an antenna adapter for a new head unit?
Old Jan 21, 2009 | 02:03 AM
DJrepresent's Avatar
Default Do I need an antenna adapter for a new head unit?
Hi,
I installed a Dual XHD6425. Sometimes when surfing channels, the radio will skip a known FM frequency. It doesn't pick up anything AM at all. I'm convinced that the antenna isn't properly connected to the HU. I'm going to take it back to the car audio installers, but wanted to know, do I need an antenna adapter? Should the shop normally have one?
DJ
Old Jan 21, 2009 | 05:58 PM
rockthebeef's Avatar
Every car stereo I've ever come across always had the standard antenna plug in the back of it. The installer could have forgotten to plug it in, or your new head unit could just have a weak tuner. I think the tuner is pretty weak in my Scion NAV head unit... I know Duals are relatively inexpensive, so maybe they scrimped a little on the radio section, but I don't know.
If time is valuable to you, you can check this yourself in about 5 minutes without having to bring it to the shop. Just pull on the trim around the radio and the whole thing will pop out with the 2 round A/C vents attached. From there you unscrew the 4 10mm bolts from around the head unit and pull it out. Take a look at the back and see if the antenna is plugged in. If not, the plug should be floating around somewhere behind the dash.
Old Jan 21, 2009 | 06:48 PM
The headunit has what I remember is something that looks like an RCA receiver that's labeled "Antenna Connector." I remember the plugs that came with the Scion don't have this RCA-like connection. Is it still possible to have compatibility?
In terms of doing it myself - no worries, I called my shop and they agreed to take a look at it.
DJ
Old Jan 21, 2009 | 07:57 PM
That RCA-looking connector is the antenna plug. Our cars definitely have this - all my cars have in the past (dating back to an old 1974 Mercedes). This is basically the other end of the lead that comes from the antenna itself.
The receptacle on the head unit looks like
the antenna plug looks like this
If you didin't see this plug then it probably is hiding behind the radio somewhere. It can easily be lost back there. It sounds like somebody just forgot to plug it in. Good luck man.
sehall6h
Scion xD ICE & Interior
Feb 21, 2016 04:28 PM
excessads
May 20, 2015 06:46 PM
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
clickclickw00t
Feb 18, 2015 08:57 PM
