wheel bearing is shot.
Old Feb 12, 2009 | 09:32 PM
teeseedriver's Avatar
Default wheel bearing is shot.
are the wheel bearings considered part of the powertrain? if not how hard are they to do on the tC? i already called about it i know they are press in which is no big deal but how much of a pain is it to get to?
Old Feb 12, 2009 | 10:20 PM
HKSpeed's Avatar
how do you know its shot? what symptoms did you notice?
typically ou have to remove the steering knuckle from the car to press in or out the wheel bearing races. i've never done it on a tC, but generally speaking i consider it a pain to get the knuckle out, but a major pain getting it back on (aligning it with the control arm, A arm, etc).
Old Feb 12, 2009 | 10:24 PM
Ace83's Avatar
Ronin Scion
depends on how mechanically inclined you are, with the right tools it should be that bad
Old Feb 13, 2009 | 01:34 AM
sciontc_mich's Avatar
^^ HKSpeed is correct, you have to take out the steering knuckle, which is basically everything to get to it. And once you take it apart, you need to re-align it, camber will be off.
Old Feb 18, 2009 | 03:33 PM
impa105817's Avatar
yea if you have extremely low mileage then u could get it done under warranty if not then they will call it a wear item
Old Feb 23, 2009 | 01:46 PM
actually its covered under tC powertrain warranty. my car has 58 almost 59 thousand on it and im getting it fixed right now.
Old Apr 13, 2009 | 09:56 PM
gdtc's Avatar
did the dealer give u any grief about it, fixing it under warranty?
reason i ask is that i got an alignment done last week and was told my front driver-side wheel bearing is starting to wear, and will need to be replaced (not immediately, but eventually).
i got ~62K miles on my car right now. how long does the powertrain warranty last?
Old Apr 13, 2009 | 10:34 PM
SCIONOSIS's Avatar
I'm surprised it was covered under pwr train warranty with the amount of miles you have... 58K? Probably was considered as a good will service on your part, cuz driving thru crazy potholes over time can cause conditional wear and tear on bearings.
GDTC - 60K/ 5 year pwrttrain warranty
Old Apr 20, 2009 | 06:17 PM
gdtc's Avatar
Thanks scionosis!. i do drive downtown alot, over alot of potholes & cracks/repairs in the road. Still, 60K seems a very short life for a wheel bearing! My previous car (Integra) made it over 150K on it's original wheel bearings.
i did buy the extended warranty (with $0 deductible) with my vehicle, thank goodness!. i can't believe it might actually come in useful for once!
Old Apr 20, 2009 | 06:23 PM
scikotictc232's Avatar
I replaced both of mine. It was pretty easy. you disconnect the tie rod, strut, ball joint, plus the nut at the end of the axle and you have the steering knuckle off, real simple if you have all the tools.
CombatmedicR56
Nov 12, 2020 01:53 AM
fur_pig
Mar 20, 2020 04:28 PM
Jordly221
Feb 13, 2019 05:29 PM
xdejablu3x
Apr 19, 2017 03:44 PM
zom6iemac
Nov 28, 2014 12:28 PM
