header install with s/c
Old Feb 18, 2009 | 09:25 PM
tc-guy's Avatar
Default header install with s/c
hey has anyone installed a header on your car after you got a s/c put in. i'm thinking of doing it but doesn't look like there's very much room to do so with the s/c shaft in the way. can someone chime in that has done it please. and yes i did search btw.
Old Feb 18, 2009 | 10:42 PM
GammaTNT's Avatar
i have the dc header installed before SC.
but i have took it off and reinstall a few times.
The only problem i see could be your heat shield have no room to wrench
Old Feb 18, 2009 | 10:43 PM
rjweitzel's Avatar
you could probobly come from under the car, that is how you have to install weapon r and tsudo header
Old Feb 18, 2009 | 11:51 PM
tc-guy's Avatar
other than the heat shield did your header come out through the top gamma?
Old Feb 19, 2009 | 01:35 AM
GammaTNT's Avatar
yes, it came out from the top. i scratch my header wrap.
I will try from the bottom next time.
Old Feb 19, 2009 | 03:10 AM
tc-guy's Avatar
just tried to see if i could take the heatshield off and i could'nt. im not about to take the s/c apart to install a header.
Old Feb 19, 2009 | 10:43 AM
jetlounge's Avatar
you dont have to take it apart. loosen bolts on the brackets holding the assembly, lift shaft...install header...replace shaft assembly.
do it. besides a pulley the header is the biggest bang for the buck on the supercharger.
Old Feb 19, 2009 | 05:55 PM
jwaggz82's Avatar
just bend the heat shield a tad and it should eventually be able to be rocked off. Myself and a bunch of other people did it w/o removing the charger.
ColonelSanders85
Dec 9, 2020 09:44 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
