cold+speakers=pop
Old Feb 19, 2009 | 09:10 PM
jct's Avatar
jct
Default cold+speakers=pop
so why do my speakers pop when its really cold outside
but its fine when its above 50 degrees outside...
and how can i fix this problem?
Old Feb 19, 2009 | 09:11 PM
SW_08's Avatar
pop?
i nvr heard of that happening....
Old Feb 19, 2009 | 10:26 PM
jct's Avatar
jct
yes pop when i'm playing my music it pop then the speaker ( front drivers side) comes alive and after a few minutes later iut starts to make a popping sound
Old Feb 19, 2009 | 10:30 PM
SW_08's Avatar
maybe something is loose....
Old Feb 19, 2009 | 11:07 PM
jct's Avatar
jct
idk
but it does not do it when its warm outside
Old Feb 19, 2009 | 11:59 PM
spr0k3t's Avatar
You have a pinched copper connection. When the temp gets cold enough the copper wire contracts just enough to separate the connection... when the area heats up, the copper reconnects. It's simple to diagnose, hard to isolate where the problem actually is though.
The easiest way to fix this issue is to trace the wire back through the harnesses and replace the problematic wires.
Old Feb 20, 2009 | 12:13 AM
jct's Avatar
jct
i did put some aftermarket speakers in and they are crimped together where they were cut
so all i have to do is tighten down the crimps some more?
Old Feb 20, 2009 | 12:21 AM
spr0k3t's Avatar
Very possible that could be the problem. Also, double check that your basket is not grounding out against the door frame.
Old Feb 20, 2009 | 12:58 AM
jct's Avatar
jct
what do you mean basket?
Old Feb 20, 2009 | 01:30 AM
spr0k3t's Avatar
The wire connecting to the voicecoil from the pos/neg terminals. If the terminals are grounding out at all, you will hear pops in colder weather from the change in copper. Try pulling the speaker out of the door and see if there are any more pops like you mentioned.
Old Feb 20, 2009 | 02:06 AM
jct's Avatar
jct
i'll try it tomorrow in the freezing cold heh
Old Feb 20, 2009 | 02:19 AM
spr0k3t's Avatar
Rock on man... my fingers are numb from installing a few things here... 30 degrees right now.
Old Feb 21, 2009 | 10:02 PM
jct's Avatar
jct
heh haven't done it yet gonna wait till it warms up a bit
instead of recrimping it i'll just solder 'em together
Old Feb 22, 2009 | 10:41 PM
SW_08's Avatar
GL
Old Feb 25, 2009 | 07:56 PM
jct's Avatar
jct
welp i soldered 'em all and one of the set of wires were just about grounded to the door from them being pinched i took care of that problem
Old Feb 25, 2009 | 08:50 PM
SW_08's Avatar
good to know....glad it worked out...
Old Feb 25, 2009 | 10:20 PM
jct's Avatar
jct
dunno if it works just yet.. have to wait till it gets cold again in a few days
i also got most of the metal shards off the magnets on the speakers
Old Feb 26, 2009 | 01:44 AM
spr0k3t's Avatar
I'm pretty sure it should be okay now that the grounding is taken care of.
Old Mar 2, 2009 | 08:33 PM
jct's Avatar
jct
gave it a good work out today fixed the problem
yupinmytC
22
Jul 27, 2024 07:08 PM
rvascion
Nov 12, 2020 03:23 AM
a23r
Feb 1, 2016 04:05 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
Subaru86
Sep 14, 2015 12:43 PM
