OBX Fuel Rail
Old Feb 21, 2009 | 08:33 PM
mravetto's Avatar
Default OBX Fuel Rail
I just finished installing a new OBX fuel rail on the box went to start it and I got fuel spurting out both ends of the rail and two injectors I thought the ends were tight and the injectors are seated properly but I think I need new o-rings and a bit of thread tape.
Old Feb 21, 2009 | 09:15 PM
Metro273's Avatar
What was wrong with the original fuel rail?
Old Feb 21, 2009 | 10:56 PM
mravetto's Avatar
Nothing just decided to get this one was told it would give a little more HP
Old Feb 22, 2009 | 06:24 PM
MadMike550's Avatar
gonna fix it today?
Old Feb 22, 2009 | 09:41 PM
snowromance's Avatar
wouldn't it just use more fuel then and decrease your mpg?
Old Feb 22, 2009 | 10:57 PM
Black_Sheep_xB's Avatar
^yes.. most performance mods do that in exchange for what they do..
____
Thats a little scary about the fuel rail, you sure all the o rings were still there when you installed the injectors, or if the machining is off on the rail.. I would pull it , inspect and reinstall it, I pulled my oem one and put it back without issue.. I have the Perrin on the way right now... its funny I went to ebay and was going to break down and get the OBX one, I did one last search for a good price on the Perrin, and *poof* one appeared
update what it was ;)
Old Feb 23, 2009 | 12:06 AM
mravetto's Avatar
Plan on doing it next weekend
Old Feb 24, 2009 | 12:01 AM
IowaSciontist's Avatar
More fuel thru the rail does you no good if you don't have bigger injectors to spray it into the cylinders. And more fule in the cylinders does you no good if you don't have a way to burn it. And you won't be able to burn it efficiently without an engine management. No need for the extra fuel if you don't have extra compression via pistons or forced induction. Plus, the stock fuel rail flows more than enough for any forced induction system on the market.
Bottom line...Fuel rail alone will get you nothing in return for your investment. In fact, it may hurt performance because you could cause a drop in pressure at the rail. Then when the injectors open, they won't spray as much as they think they are.
Old Feb 24, 2009 | 10:29 PM
Sciond's Avatar
^^^^ correct you will just make your catalytic converter work harder
Old Mar 3, 2009 | 01:20 PM
mravetto's Avatar
Well I took off the OBX rail I replaced the O-rings but I cannot get the threads on the fuel in side to seal I tried thread tape ate right through it and then I got this oil and gas resistant sealant from autozone and after two tries I put the stock rail back on. Not sure if I am going to put the OBX back on for another try.
Old Mar 10, 2009 | 06:07 AM
firesquare's Avatar
their is no reason too unless your pushing over 170 at the wheels
steeze69
May 24, 2021 02:57 AM
mudguy
Oct 22, 2015 04:31 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
paisatronix
Sep 5, 2015 04:13 AM
