before putting in the supercharger...
can i put the new injectors/fuel line, spark plugs, radiator hose/thermostat , reflashed computer before actually putting the supercharger in? just had some time before the acutal install date and wanted to get some things off the to do list. Also is the new crank bolt necessary? just wanted to know if anyone has driven s/c'd without replacing the factory one, i have it to go on just not sure the difference and such a timely procedure in replacing just a bolt.
No you don't really need that bolt but if it comes with it install it. Might as well. Why would you install those parts if your taking it to be installed somewhere? If your doing it yourself then go for it.
You shouldn't have a problem with installing those things prior to installing the S/C, just don't drive the car hard. It might run like ___ if you try to push it.
26scionxb26
11
Jun 11, 2015 12:48 AM
Erager09
Apr 23, 2015 01:50 PM
