before putting in the supercharger...
Old Feb 25, 2009 | 04:35 PM
blitztc06's Avatar
Default before putting in the supercharger...
can i put the new injectors/fuel line, spark plugs, radiator hose/thermostat , reflashed computer before actually putting the supercharger in? just had some time before the acutal install date and wanted to get some things off the to do list. Also is the new crank bolt necessary? just wanted to know if anyone has driven s/c'd without replacing the factory one, i have it to go on just not sure the difference and such a timely procedure in replacing just a bolt.
Old Feb 25, 2009 | 04:40 PM
streettimetc's Avatar
i dont think its the fly wheel bolt. if its the bolt that im thinking of its the crank pulley bolt. s/c install does not call for the fly wheel or clutch to be messed with.
Old Feb 25, 2009 | 04:42 PM
blitztc06's Avatar
sorry meant crank bolt
Old Feb 25, 2009 | 04:45 PM
m6ar2cel6oTC's Avatar
No you don't really need that bolt but if it comes with it install it. Might as well. Why would you install those parts if your taking it to be installed somewhere? If your doing it yourself then go for it.
Old Feb 25, 2009 | 04:49 PM
java09's Avatar
I have nothing productive to say
*edited* by Sciond
Old Feb 25, 2009 | 04:59 PM
O5_TRD_tC's Avatar
^LOL
Old Feb 25, 2009 | 05:06 PM
CarbonXe's Avatar
You shouldn't have a problem with installing those things prior to installing the S/C, just don't drive the car hard. It might run like ___ if you try to push it.
Old Feb 25, 2009 | 05:19 PM
THansenite's Avatar
The flashed computer and bigger injectors will make the car run super rich since it is expecting boost but not seeing any.
Old Feb 25, 2009 | 10:36 PM
java09's Avatar
*edited* by Sciond
And I still don't. Not in this thread anyway.
*edited by java09*
26scionxb26
11
Jun 11, 2015 12:48 AM
Erager09
Apr 23, 2015 01:50 PM
blue_xB_23
Mar 19, 2015 10:29 AM
yhwhdesign
10
Feb 6, 2015 05:00 AM
