will this wiring work?
Old Mar 1, 2009 | 06:44 AM
mrfuzzy4's Avatar
From: 'Burbs Farmington Hills - go to school in Boulder, CO
Default will this wiring work?
I'm helping my friends with some wiring. They want to wire some super bright led's (~3v) into their table, and want the switch to plug into the wall, and want as many as possible. I'm no pro, so I figured I'd ask you guys if this is right.
a wall outlet is 120volts, or 20amps, and should only be used to about %80 of power for safety, which means 100v or 17amps
so if you hooked up the led's in a series circuit, you could use about 32 leds safely, right?
also, if anyone can figure it out, what is the amp of those 3v leds? i couldn't figure out the wattage, so if anyone knows, that'd be nice.
and if they used regular leds, they could hook up 800, so that's a bit too much.
any tips or ideas would be good too. thanks!
Old Mar 1, 2009 | 06:51 AM
kileil's Avatar
LED's like DC.
Old Mar 1, 2009 | 07:03 AM
mrfuzzy4's Avatar
ok, so it sounds like LED's might be too hard, so how could i hook up cold cathodes?
I would need like 8 or so, and they are 12v .3amp, so i would need like a 3amp ac-dc box?
Old Mar 1, 2009 | 09:39 PM
jct's Avatar
jct
use a power converter make it easy on your self and use a ac/dc universal power converter
Old Mar 1, 2009 | 09:44 PM
mrfuzzy4's Avatar
for the LED's that wouldn't work
but if i use the cold cathodes, i'd need like a 3amp converter, because i'd need like 8. or a 2 amp. anyone know anything about this?
Old Mar 1, 2009 | 11:21 PM
tCscotty's Avatar
Use a 120v a/c to 12v d/c converter. I use one to test my led circuits. You'll just need to use the correct resistors.
Here's a led circuit calculator.
http://ledcalc.com/#
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
clickclickw00t
Feb 18, 2015 08:57 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
xdejablu3x
Regional - Mid South
Dec 29, 2014 02:15 AM
