Royal Purple Gear oil
Old Mar 2, 2009 | 04:30 PM
combatsteve's Avatar
Default Royal Purple Gear oil
I recently changed out my manual transmission fluid with Royal Purple of the recommended weight in the owners manual and now when the car is cold it doesn't shift was well in first and 2nd gear. I filed it up until fluid came out of the fill hole (~2 quarts I think) so there is plenty of fluid. Has anyone else experienced this?
Old Mar 2, 2009 | 05:22 PM
ack154's Avatar
Welcome to the world of synthetic trans fluid. I guess...
I swapped out for some Reline MT-90 last summer and noticed similar results. I mean, it's not really HARD to shift or anything... but there's a noticeable difference until it warms up.
Old Mar 2, 2009 | 05:35 PM
yeah there is def a noticable difference until it warms up. Especially going into first. I am feeling like there is no way this can be good for the tranmision.
Old Mar 2, 2009 | 05:38 PM
cavalierkid888's Avatar
I get the same thing, didn't know it was due to the synthetic trans fluid though.
I switched to synthetic before winter so I just figured this happens when the car is cold to everybody...
Old Mar 2, 2009 | 06:29 PM
hotwheelsrs1's Avatar
should b just under 3 quarts...
Old Mar 2, 2009 | 06:47 PM
draxcaliber's Avatar
should be 2.6 quarts of oil.
i just changed mine to mobil 1 synthetic gear oil, seems to be running great, but i haven't had a really cold morning start to notice any differences yet.
Old Mar 2, 2009 | 07:58 PM
maybe that is what is was. I don't remember it was about a month or so ago. I know I bought 3 quarts. either way i filled it until it came out of the fill hole.
Old Mar 3, 2009 | 02:57 AM
i just checked and i have about a half a qt left so i put it ~2.5 qts
Old Mar 3, 2009 | 03:03 AM
Mouse's Avatar
well it depends on the temps you are talking about for cold starting... there are a couple of options... Are synthetics better? well in the tranny... probably over time yes. but if the temp is low enough its going to like pulling a stick through the mud. Only other option is to just give the engine/trans enough time to warm up a bit then take off.
Old Mar 3, 2009 | 01:27 PM
cold temps I am talking about are right around freezing, 32 deg F. But my car is garaged too so the temp in there prob is in the 40's I can check later when when I get home, I have a thermometer in there
Old Mar 4, 2009 | 03:20 AM
temp in the garage is like 45 right now
Old Mar 5, 2009 | 01:54 PM
so i guess I shouldn't worry about this?
Old Mar 13, 2009 | 06:46 PM
a-mendoza's Avatar
Default Re: Royal Purple Gear oil
Did you use Royal Purple Gear-Max or Synchromax?
Old Mar 13, 2009 | 07:10 PM
unxpectederror's Avatar
when its cold out my car does a funky shift from 1st to 2nd like its popping out of 1st as im shifting. but i have the oil that came with the car, whatever that is
ffodge
Apr 25, 2015 07:03 PM
kleecker
Apr 4, 2015 02:37 PM
edwinisdumb15
Regional - Pacific South
Dec 9, 2014 11:20 PM
DGTLLVR
Apr 7, 2004 07:08 PM
subcode
Feb 22, 2004 11:41 AM
