What shock do you use when u bag xb
Old Mar 4, 2009 | 05:07 PM
davidward's Avatar
Default What shock do you use when u bag xb
My xb has been bagged for the past 3 years.. I never got around to buying shorter shocks.. What do you recommend. I have heard you can use the echo shocks, but i dont know..
Old Mar 4, 2009 | 09:52 PM
RedneckwithanxB's Avatar
I had two different setups... one was the echo monroe rear shocks... the second was just a chain that I welded onto the rear I beam and made a little eye hook that bolted into the top shock mount... didnt really help in the the dampening of the car, just kept the suspension from extending too far and let me go lower than any shock...
Old Mar 7, 2009 | 03:48 PM
Gothbox's Avatar
I have yet to bottom out my shocks other things stop the car before it has happened, like the tires sit in the fender wells, or the rear arm is sitting on the body of the car.
Old Mar 15, 2009 | 03:49 AM
mxvris08's Avatar
your rear arm hits the body before your stock shocks bottom out?????
when my shocks bottomed out i still had 3+ inches before the arm hit the body.
Old Mar 15, 2009 | 03:51 AM
Gothbox's Avatar
yeah the best I can tell they don't bottom out.
I can see on the arm where it has rubbed a clean spot on it.
Old Mar 15, 2009 | 04:10 AM
What brackets do you have on yours goth? I modded my FBI brackets and bottomed out the shock before the bag even hit 20psi
Old Mar 15, 2009 | 04:15 AM
Gothbox's Avatar
I am running modded Easy Street sleeve bags and brackets, removed the top spring mount and the top bracket sits flush to the frame of the car.
I think I have a pic, let me try and find it.
Old Mar 15, 2009 | 04:26 AM
Gothbox's Avatar
Old Mar 15, 2009 | 04:30 AM
I ran the reg bellow bag... maybe that is the variable, since your upper spring mount seems to maybe be a little closer to the body
Old Mar 15, 2009 | 04:32 AM
Gothbox's Avatar
thats what I am saying, I removed the OEM, top spring perch, and modded the bracket so that it sits flush on the car now.
Old Mar 15, 2009 | 04:38 AM
Damn you and your mad sciontist esq fabrication! LOL
Old Mar 15, 2009 | 04:41 AM
Gothbox's Avatar
thats how I roll, LOL
Old Mar 16, 2009 | 10:53 PM
Stylis's Avatar
I was using KONI adjustable dampening struts all around and those things worked the best because even when I was almost all the way down I would adjust the dampening and was not bouncy at all. BUT they are pricey and last longer though.
Old Mar 27, 2009 | 11:39 AM
Box916's Avatar
I went and bought some rear shocks from NAPA auto for $50. pm MYBOX aka Sean because I cant remember the p/n.
jthistle
10
May 9, 2016 09:48 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
Darrenohooligan
Sep 26, 2015 07:21 AM
user9430961
Sep 24, 2015 01:09 PM
BlingSlade
Sep 5, 2015 08:52 AM
