Xa Caliper Bolts
Old Mar 6, 2009 | 09:32 PM
XaElmo's Avatar
Default Xa Caliper Bolts
Hello you all,
My first post.......I am having trouble removing the calper bolts from my '05 Xa. They seem to just turn when I try to losen them and won't come out. Whats up w/ that?
Old Mar 6, 2009 | 09:52 PM
jct's Avatar
jct
have you tried to put some tension on 'em with some thing like a screw driver...
Old Mar 6, 2009 | 10:14 PM
XaElmo's Avatar
the 14mm bolt seems to just spin in place when I turn it and not unscrew out, How would a screw driver help?
Old Mar 6, 2009 | 11:21 PM
Metro273's Avatar
Pull the rubber boot back and hold the slide pin with a thin set of pliers, maybe even vise-grips. Then use the 14mm socket or ratchet and turn the bolt...good luck!
Old Mar 6, 2009 | 11:46 PM
XaElmo's Avatar
thanks so much I will try this
Old Mar 10, 2009 | 02:00 AM
firesquare's Avatar
a 14 socket on the outside end and a opened end 14 on the bolt inside the caliper. and one good jolt and your good to go :-)
Old Mar 10, 2009 | 06:54 PM
XaElmo's Avatar
Thanks for the info.......I thought its was as easy as that.....but wasn't sure......will work it out tonight.
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
rvascion
Nov 12, 2020 03:23 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
crimson_sinn
Sep 25, 2015 09:41 PM
