Xa Caliper Bolts
Xa Caliper Bolts
Hello you all,
My first post.......I am having trouble removing the calper bolts from my '05 Xa. They seem to just turn when I try to losen them and won't come out. Whats up w/ that?
Originally Posted by jct
have you tried to put some tension on 'em with some thing like a screw driver...
Originally Posted by Metro273
Pull the rubber boot back and hold the slide pin with a thin set of pliers, maybe even vise-grips. Then use the 14mm socket or ratchet and turn the bolt...good luck!
Originally Posted by firesquare
a 14 socket on the outside end and a opened end 14 on the bolt inside the caliper. and one good jolt and your good to go :-)
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
rvascion
11-12-2020 03:23 AM
crimson_sinn
09-25-2015 09:41 PM
