Somthing wrong on start up? please help
Old Mar 29, 2009 | 09:19 PM
pinnola4life07's Avatar
Default Somthing wrong on start up? please help
soo i get into my car put the key in and i would say every 1 outta 10 times it is such a dellayed start. The best way i can explain it is as if u were not turning the key far enough and it like putters and putters and then finally turns over. Now the car never has failed to start and it doesnt make a difference whether it is hot or cold outside. Any idea of what this might be...? Its not my battery..
Old Mar 29, 2009 | 09:47 PM
kileil's Avatar
If you're only talkin a few extra cranks, its natural w/ the tC's returnless fuel system. No worries.
Old Mar 29, 2009 | 10:19 PM
yeah sometimes it goes a few extra cranks but like thats not it....it like half starts up...then doesnt and is almost fully started and turns off and then while still holding the key in the same spot...will start up again
Old Mar 29, 2009 | 11:21 PM
aen's Avatar
aen
check your vacuum lines
one of htem off could cause a hard start
check engine light?
Old Mar 30, 2009 | 04:45 AM
aen's Avatar
aen
turn the car on and listen for hissing, that means a vacuum line is leaking
Old Mar 30, 2009 | 05:14 AM
senseiturtle's Avatar
Normal.
Has to do with the returnless fuel system, as well as temperature changes. If it changes >20* in a few hours, such as after a cold front, it'll be a little rougher than the usual.
If you're running a CEL or it fails to turn over, then get back to us.
Old Mar 30, 2009 | 05:37 AM
Mos_Def's Avatar
^yep mine is the same way sometimes. its a normal thing.
Old Mar 30, 2009 | 06:17 AM
aen's Avatar
aen
take a video it could be your perception of a long start that is throwing us off.
Old Mar 30, 2009 | 04:22 PM
thanks for all your input umm im not running a CEL and its not a long start up....there is a slight hissing...im going to monitor it for a few more weeks...if i feel somthings wrong ill take it in...does the vacuum lines have anything to do with the CAI i have the TRD CAI installed...
Old Apr 1, 2009 | 02:18 AM
Scionyde0613's Avatar
got something of a similar problem after i fill up my car has a really bad idle like its gonna stall but im sitting in neutral
Jordly221
Feb 13, 2019 05:29 PM
hampton1100
May 28, 2015 07:32 AM
Scionxa180
Mar 22, 2015 01:14 PM
mw1957
Mar 16, 2015 06:00 PM
idriveanxa
Mar 8, 2015 12:03 PM
