Wheel Bearings!!!! HELP PLZ!!!!
Old Apr 15, 2009 | 03:15 PM
alenehan's Avatar
Default Wheel Bearings!!!! HELP PLZ!!!!
I have to replace my front wheel bearings this weekend. There are a handful of torque to yield parts and cotterpins that cannot be reused... Does anyone know the part # or specs of these bolts/cotterpins etc? I don't have a repair manual...Thanks!
Old Apr 15, 2009 | 07:20 PM
streetracer99x's Avatar
Go to the dealer.... They will show you every part number and price for each item.
Old Apr 15, 2009 | 07:47 PM
alltracman78's Avatar
All you'll need to replace is the bearing, seals [they might come with the bearing, don't know] and the cotter pins for the outer tie rod and lower ball joint.
Depending how you treat the axle nut you might or might not be able to reuse it.
This also of course assumes you don't damage anything like the axle threads, outer tie rod or ABS sensor.
Old Apr 16, 2009 | 04:16 PM
alenehan's Avatar
thanks guys
Old Apr 20, 2009 | 08:16 PM
alenehan's Avatar
If anyone else is gona try this....
you need
new bearings, new cotterpins, new snaprings (To retain the bearings) and new axle nuts (probably)
the wheel studs on my car were reuseable
also, the socket to get the axle nut off is like a 32mm 12 point!!!! so find some big metric 12s first!!!
Old Apr 21, 2009 | 03:40 AM
I forgot about the C clip [Snap Ring], sorry.
The axle nut is a 30MM 12 point [OEM anyways, if you have an aftermarket axle or nut it could be a different size].
Old Apr 21, 2009 | 06:14 PM
aen's Avatar
aen
make a guide. i'll put it in the tech section
CombatmedicR56
Nov 12, 2020 01:53 AM
fur_pig
Mar 20, 2020 04:28 PM
Jordly221
Feb 13, 2019 05:29 PM
xdejablu3x
Apr 19, 2017 03:44 PM
zom6iemac
Nov 28, 2014 12:28 PM
