NEED MORE POWER.....
Old Apr 21, 2009 | 09:05 PM
TJxxAZUL's Avatar
Default NEED MORE POWER.....
well im new at this forum... but i was wondering wat can i do to my tC to squeeze out more power... any of u got suggestions...?.. i got the cold air intake but thats it.. n i cant afford a turbo or s/c... haha.. but i got 800bucks saved up.. so any suggestions that can help?....
Old Apr 21, 2009 | 09:07 PM
stevejohns29's Avatar
Light weight pulleys always help some. Exhaust system?
Old Apr 21, 2009 | 09:09 PM
Brian_M1Autosport's Avatar
Banned for NON PAYMENT
exhaust? headers?
TJxxAZUL's Avatar
i heard the about the pulley... ima look at that... oh n i got the TRD exhaust...
cavalierkid888's Avatar
catback exhaust, header (you'll have rasp), pulleys
That's pretty much it, and even with all three of those you'll only squeeze out a few extra hp. Not much you can do to the tC aside from f/i to really see some gains.
we have them in stock
LMK
Old Apr 21, 2009 | 09:10 PM
TRD exhaust sounds good but no power gains from it.. Look into a catback at least.
Old Apr 21, 2009 | 09:12 PM
TJxxAZUL's Avatar
Originally Posted by Brian_M1Autosport
exhaust? headers?
yo u work at m1...lol i been there so many times...
Old Apr 21, 2009 | 09:15 PM
TJxxAZUL's Avatar
LMK
wat u got in stock?
Old Apr 21, 2009 | 09:17 PM
ecko04's Avatar
NITROUS FTMFW
Old Apr 21, 2009 | 09:23 PM
TJxxAZUL's Avatar
Originally Posted by ecko04
NITROUS FTMFW
but doesnt nitrous kill ur engine?.... i dont want that....
Old Apr 21, 2009 | 09:27 PM
AlanW's Avatar
Sounds like a bit more research needs to be done...
Anyways, the main point is, you won't break 200whp with bolt-on's, cept for maybe nitrous. Keep saving up for a turbo, like myself. I came to this realization AFTER I got I/H/E, so now I regret not saving up the $1000 I spent on getting those.
All those power upgrades, aren't going to give you a noticeable power gain. Maybe the first few days the butt dyno is going to feel a bit of it, but you'll soon realize you still have under 200whp.
Old Apr 21, 2009 | 09:28 PM
Sciontistical_One's Avatar
nitrous doesn't kill your engine if it's done right... been there, done that... having to refill the bottle once a week was a pain in the rear for me... at least $30 per refill
Old Apr 21, 2009 | 09:29 PM
ecko04's Avatar
Nitrous does not kill your engine anymore than the supercharger or turbocharger. It is another F/I way to go.
As always it is worth doing your reading beforehand. There are quite a few guys here that have gone with nitrous setups and not one of them has "killed" their engine.
Old Apr 21, 2009 | 09:30 PM
ack154's Avatar
Before you bother spending much money on small bolt ons that won't really do much for you... might I recommend: Rear sway bar.
After that...
- lightweight/underdrive pulley
- header
- full exhaust (will need a big resonator to calm the bees)
- um... that's kind of it.
If you spend much beyond that, you should have just bought a turbo anyway.
Old Apr 21, 2009 | 09:33 PM
kuo34's Avatar
As stated above, i/h/e. The stock midpipe will cut down on the noise and rasp a little from the weight and cat (I'm guessing that's what keeps it down). Lightweight or underdrive pulleys will work, as well as a lightened flywheel. Nitrous is an option if done correctly. You could also get some engine management and a tune. It all depends on what your goals are. If you want a little bump in hp then n/a is the way to go. If you want to make tons of horse, go f/i.
Old Apr 21, 2009 | 09:34 PM
TJxxAZUL's Avatar
well here the thing.... its an automatic.... i dont think they got auto turbos out there... are there?
Old Apr 21, 2009 | 09:36 PM
ecko04's Avatar
Of course they have turbo's, superchargers and nitrous for auto's.
You can get 230+ whp running nitrous with a conservative 75 shot and a decent kit pretty much stock with no bolt-ons.
The bottle will cost between $30 and $45 to get filled so those costs add up. After you buy the kit and get about 70 refills you could have bought a turbo.
The turbo will require maintenance and other tunes and fuel management to get the most out of it.
New tires will be needed for both and this doesn't even begin to explain either nitrous or turbochargers.
Old Apr 21, 2009 | 09:38 PM
kuo34's Avatar
TRD s/c can work on an automatic, just requires an additional fitting kit (or so I've read). Aftermarket turbo should be okay as long as your transmission can handle it. Go over to the forced induction forum for more information on that. Most of the f/i guys I've seen are manual transmissions, but there are a lot of examples of automatic tranny turbos across several platforms.
Old Apr 21, 2009 | 09:41 PM
crg5990's Avatar
my friend had a turbo automatic. it can be done but you wont make much over 240hp or else the tranny starts to slip. i/h/e and pulley's are really all you can do to it before going f/i
