If you're tee-ing into oil pressure sensor for supply line!!
Old May 9, 2009 | 12:40 PM
xa007xa's Avatar
Default If you're tee-ing into oil pressure sensor for supply line!!
make sure that it is sealed!!! greddy's sheet says to use teflon tape that works fine... I went with pipe dope that is safe for oil and gas lines instead. The problem i ran into recently was that because of the location of the oil pressure sensor, the tee fitting was 90 degrees short of being tight. So, oil leaked out of the fitting and ran down the block and creeped through the housing where the starter bolts on. eventually oil got on the clutch and caused my clutch to fail prematurely. When i switched to pipe dope, i was able to get another 360 degrees of rotation and gave me both the location and tightening i wanted. just a heads for all of you diy people.... im not too sad about the clutch failing prematurely because i was planning on putting a stage 4 on this summer anyways
Old May 23, 2009 | 01:42 AM
BlueJDMBoxV2's Avatar
good heads up. Thanks.
Old Jun 22, 2009 | 06:48 PM
vettereddie's Avatar
I'm using a sandwich adapter for the feed. Turbo isn't installed yet, so right now I have three plugs and the oil pressure sensor. I did notice the one plug where I will be putting the oil feed line has a very slight leak, about 1-2 drips every 5 minutes. Nothing below it though but the ground, so no risk of contaminating anything else. I was planning on using oil-resistant RTV on the threads when I run the oil feed to seal it, my understanding was that teflon wouldn't stand up to the oil temps. What is pipe dope and where di I get it?
Old Jun 22, 2009 | 07:48 PM
xa007xa's Avatar
you can get pipe dope at the hardware store. it's like a paste. just make sure the kind u get is oil resistant.
Old Jun 22, 2009 | 07:51 PM
TY, sounds like a trip to Lowes or True Value then.
Old Jun 22, 2009 | 08:05 PM
xa007xa's Avatar
no prob. good luck.
my06tc
Jun 25, 2015 12:18 AM
08bakerXxtc
Mar 19, 2015 09:51 AM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
kingofthecrate
Jan 21, 2015 09:28 PM
eric_m
79
Mar 17, 2013 12:21 AM
