HID lights with Projection headlights
Old May 12, 2009 | 03:47 AM
valkyrie6x6's Avatar
Default HID lights with Projection headlights
I just got a set of Sonar Projection head lights, a label on them says not for use with HID lights.
Has anyone installed HID lights with projection headlights?
Is this something to pay attention to or can I use HID low beams?
Thanks in advance for all replies.
Old May 12, 2009 | 04:59 AM
SentraSE-R's Avatar
Read this and you'll understand why do-it-yourself HID kits don't cut it.
Old May 12, 2009 | 05:25 AM
Gee, thanks, I just had a question, and you had to be a smart a$$
Old May 12, 2009 | 05:52 AM
spr0k3t's Avatar
The sonar's have a very nice cutoff with HID kits. I've seen good and bad reports. You get what you pay for in the kit though, keep that in mind. Research the kit you buy and make sure you get one that is worth every penny.
Just whatever you do... don't put HIDs in a reflector housing.
Old May 12, 2009 | 06:02 AM
SentraSE-R's Avatar
Well, pardon me for answering your question. Next time, if you don't like the answer, don't ask the question ;).
Old May 12, 2009 | 06:24 AM
snowromance's Avatar
i have seen someone use them and he didn't have any problems.
Old May 12, 2009 | 07:27 AM
SentraSE-R's Avatar
That's pretty doubtful. With the haphazard filament alignment that comes from inserting HIDs into mismatched reflectors, massive light scattering is almost guaranteed. There's another website out there that contains photos of the horrible real-world effects of HIDs inserted into projector lenses. Here's the link Scroll on down to the photos and see what you get with HIDs that aren't properly matched with reflectors as complete assemblies.
Old May 12, 2009 | 01:24 PM
spr0k3t's Avatar
The Sonar low beam housing are projectors with proper cut-off assemblies. Using a properly matched 9006 HID bulb in the Sonar housing will not magically scatter the glare due to improper fitment. Check these threads for some examples.
https://www.scionlife.com/forums/viewtopic.php?t=185754
https://www.scionlife.com/forums/viewtopic.php?t=153748
Now, here's an example of someone who doesn't research the problems of HIDs in reflector housings:
Now, putting the HID bulb in the location for the high beams on the Sonars is just dumb.
Old May 12, 2009 | 02:44 PM
burstaneurysm's Avatar
Here's my cutoff with 55W HID in my sonars. It's perfect. Game. Set. Match.
Old May 12, 2009 | 03:32 PM
SentraSE-R's Avatar
Pretty convincing, I'll admit.
Old May 12, 2009 | 03:42 PM
Zero glare, razor sharp cutoff. It's perfect. HID in a reflector based headlight is where you get nasty glare, and H4 base is even worse (since the low and high beam is housed in the same reflector).
Inazuma
20
May 3, 2023 01:58 AM
umnitza
Dec 1, 2014 06:26 PM
zeroflamegt
19
Dec 6, 2003 09:12 PM
